On my Turnigy Accucel, A123 cells in 6S configuration charge until 21.6V is reached (3.6V per cell).
The first charging phase is Constant Current (CC) - in my case 1.8A - during which my cheap 12V charger sees approximately a -1V voltage drop, at 19.8V constant output from the Accucel. That's theoretically 19.8*1.8=35.64W (not accounting for any loss), so that's about 3A draw from my cheap chinese charger which is rated 5A. Safe margin
The following Constant Voltage (CV) phase doesn't require much (if any at all) current, so the 12V charger sees no voltage drop. This is when balancing occurs, at approximately 20.6A => note that this figure varies, as the capacity is distributed amongst cells until 3.6V is reached for each cell...or in my case never
(because I need to cycle my cells a bit more for the proper balance to be achieved)
I guess the figure you quoted (25.2V) applies to LiPo, not nanophosphate technology (LiFePO4 et al.), right?
Cheers, Dan
Doesn't mean it will do it at 25.2v though... ;-)
Check for yourself... Or read the instructions for the charger it says so there.
It'll do the 6 amp charge with the following combinations :-
60 Watt Max Charger (As they circuit protected)
2s = 8.4v @ 6amp = 50.4watts
3s = 12.6v @ 6amp = 75.6watts Actual Max 4.7amps
4s = 16.8v @ 6amp = 100.8watts Actual Max 3.5amps
5s = 21v @ 6 amp = 126watts Actual Max 2.8amps
6s = 25.2v @ 6amp = 151.2watts Actual Max 2.3amps
