I think it's about what gear you are in. ALP has no issues with hill starts in a low gear, but in a high gear can be sluggish both uphill and on flat (as you say, presumably to protect the chain).Hmmmm .... having had the Crossfire with a rear hub motor and now the Crossfuse with a Bosch active line plus, I would have to say to the poster above that the rear hub motor gives a much bigger boost from a standing start. I think it's designed in to rear hub motors because they can put a lot of power through at start up without stressing the chain (but might be wrong). The Bosch ALP is ok but it doesn't deliver its proper power levels until you are doing 50- 60 cadence (again that's from memory and I might be wrong).
Mike
