Bike not moving when putted on the ground
Yves
49
7
Hi,
Picture 1 and 2 (With The letters of the freewheel faced towards you): clockwise it pulls , counterclockwise it freewheels. The thread goes from the leftside up to the rightside down, so I suppose this is left threaded? The inside diameter is 3,5 cm or 1,38 inch.
Picture 3 is the opposite side of the freewheel. Here they put on some kind of adapter ( the black part) . The diameter is also 3,5 cm or 1,38 inch. With the adapter facing towards you, turning the wheel clockwise it freewheels, counterclockwise it pulls. The thread goes from leftside down to the rightside up, so I suppose this is right threaded?
I dont have the right tool to determine the tpi. On the internet there are also printable tables available but my printer doesnt work for the moment... :s.
I counted the threads manually on the black adapter as it has the same tpi as the internal thread. There are 5 threads for about 0,5 cm. ( that should give me 25,38 tpi?)
Controller and motor are still working.
Regards
16,977
can you post a picture of the other side of PIC3? the one with the adapter?
16,977
the issue is choosing the right hub to install the freewheel on picture 3.
It has normal, righthand thread so should fit a flipflop hub.
Yves
49
7
Yes i also think so , and what if i find a normal wheel with thread on it? If i flip the Wheel over and I dont use the adapter? ( it could be that i have another bike at my grandmothers place that has not been used for years)
16,977
if you flip a normal wheel over, it won't be road legal because you can't pedal.
look for a single speed fixie wheel.
16,977
it's mostly standard.
I have only had an odd TPI thread some 10 years ago with a motor on the Woosh Angel but that was just an odd case, had to source the freewheel from the supplier of the motor.
Yves
49
7
Oh ok !
Yves
49
7
Hi, would the following wheel work? https://webshop.vlechtservice.nl/en/webshop/wielen-nieuw/a-wiel-622-700c-28/flipflop-xpace-zwart/
They would make the wheel stronger for me as it is a heavy bike.
If I choose a fixed hub, wont the pedals spin if i start the motor? Or is that just the purpose, so that my manual peddeling is supported by the motor?
16,977
you have two freewheels, the normal freewheel on your right works like a single speed freewheel, the one on your left is driven by the motor. When the motor is on, the wheel moves but chain does not have to move.
Yves
49
7
Ok thx, so the Wheel i showed should work?
16,977
yes.
Yves
49
7
Ok, I got the new wheel I mentioned. The freewheel that was delivered together with the motor indeed fits this wheel.
Only one problem , the freewheel is freewheeling counter clockwise, and is fixed when turning clockwise. I suppose in this case, I would drive backwards when i put the motor on the bike...? So i should need another freewheel?
Yves
49
7
Hi,
The bike Works! thx @Woosh :)
I have got a flipflop hub. I mounted the motor on the fixed side. Last weekend, I drove the bike in my street ;)
Today, I Connected the pedals with the freewheel with a new chain. I will try out how that works, but I guess that should not be a problem.
Thx guys!
