December 7, 201510 yr So if you were in the market for a new 36v battery .........what would you reckon as the best value proposition right now ? Let's say min requirements are 10ah and 20a continuous discharge. Taking your subjective views on price /uk supplier / overseas suppliers / guarantees / customer services / size/shape etc etc .... What would you buy ? (And why - if you can be bothered!
December 7, 201510 yr I would contact the Company in London that re-celled my Batribike Battery in under a week and see what they have available , they will even build it to your requirements . If you have an existing one they will re-cell it for you .They are Martex Electronics , t/a INSAT International at Bounds Green , London N11 2UT .
December 7, 201510 yr Their ebay site is : http://www.ebay.co.uk/itm/Insat-Li-NMC-eBike-Battery-Electric-Bike-10-15Ah-24V-36V-48V-e-bike-battery-/331485310419?var=&hash=item4d2e106dd3:m:m8c7FUsp_phLtXj3YKUmfLQ which discusses their re-celling.
December 7, 201510 yr If in a year or two I need to replace I would consider Insat for recelling they can fit pucker Panasonic 3450mah cells so my 14.5/15ah 09 battery could increase to 17.25ah. For a complete new one Eclipse or Woosh for some guarantee, the HL/Halong 08 battery is a bit sleeker then the older 09 type. I have just paid £196 for a 11ah one from Oxydrive on a Cyber Monday deal but the battery is not a generic one. On another recent thread someone mentioned that Oxydrive / H7 may have some old stock batts of about 17ah left over so may be worth a phone call to make an enquiry. Edited December 7, 201510 yr by Nealh
December 7, 201510 yr this 11.6AH bottle battery with charger costs £265 from woosh including shipping may not be the cheapest but I think you should consider it for its special qualities. It has high discharge (30A BMS) to support the BBS02 500W, lightweight, Samsung cells, and right side pull fitting for the smallest form factor. Woosh will probably knock £25 off if you don't need the charger. http://wooshbikes.co.uk/?batteries http://wooshbikes.co.uk/2015/battery/DT-36V12AH.jpg
December 8, 201510 yr It was d8veh who said Oxygen had surplus 17ah batteries he reckons about 200 notes.
December 8, 201510 yr Author Called oxygen but only have 15.5ah at 260 without charger (silver fish style) Trex - hmmm, interesting
December 8, 201510 yr this 11.6AH bottle battery with charger costs £265 from woosh including shipping may not be the cheapest but I think you should consider it for its special qualities. It has high discharge (30A BMS) to support the BBS02 500W, lightweight, Samsung cells, and right side pull fitting for the smallest form factor. Woosh will probably knock £25 off if you don't need the charger. http://wooshbikes.co.uk/?batteries http://wooshbikes.co.uk/2015/battery/DT-36V12AH.jpg What is a 'right side pull fitting' and how does it make it a smallest form factor ? Does that make it different from other bottle batteries, like the one on my 8fun kit ?
December 8, 201510 yr with most downtube batteries, you lift the battery up or push the battery forward to remove. You need about 1 inch of space in front or above the battery to take it out of its cradle. With the right pull bottle, the battery swings out, like on the picture, you can fit it where space is very tight, like inside the triangle of this small size full sus bike. The side pull battery has 5-blade contactor, much more tolerant of jolting than XLR or spring loaded prongs. The HL battery (case 08) would just about fit this bike but you would scratch the casing each time you pull it out, the square bottle (case 09) won't fit this bike. The features of this 11.6AH battery are the 3C cells and 30A BMS, designed for use with BBS02 36V 25A 500W and full sus bikes.
December 8, 201510 yr with most downtube batteries, you lift the battery up or push the battery forward to remove. You need about 1 inch of space in front or above the battery to take it out of its cradle. With the right pull bottle, the battery swings out, like on the picture, you can fit it where space is very tight, like inside the triangle of this small size full sus bike. The HL battery (case 08) would just about possible to fit to this bike but you would scratch the casing each time you pull it out, the square bottle (case 09) won't fit this bike. The features of this 11.6AH battery are the 3C cells and 30A BMS, designed for use with BBS02 36V 25A 500W and full sus bikes. Yeah i can see the point of them now, i wasn't familiar with these batteries. On a different note, i'm still wanting to see pics and details of your Giant Defy with the kit fitted.
December 8, 201510 yr I left my D5 with SWX02 wheel at woosh in Southend, they are going to fit the GSM to it for me to test before I decide which to keep. Back home Tuesday week.
December 8, 201510 yr I left my D5 with SWX02 wheel at woosh in Southend, they are going to fit the GSM to it for me to test before I decide which to keep. Back home Tuesday week. Ok cool..... it'll be very interesting to me to see it and your views on which you prefer. Still cant really make up my mind whether to fit a kit to mine or not.
December 8, 201510 yr Author Called up instat recellers. Spoke a hugely knowledge chap there called Jimmy. 20 mins talking 18650 cells,. C rates, internal resistance etc !! And still no price Prices to follow but there is no doubt at all that he knows his onions and really cares about the quality of his work.
December 8, 201510 yr Called up instat recellers. Spoke a hugely knowledge chap there called Jimmy. 20 mins talking 18650 cells,. C rates, internal resistance etc !! And still no price Prices to follow but there is no doubt at all that he knows his onions and really cares about the quality of his work. This does sound like a good route to use in the future, a uk base company with no need to worry about import and vat and other extras, also in case of the 08 or 09 batteries the chance to upgrade cells as more ah becomes available.
December 8, 201510 yr Author I was quoted 320 quid for a brand new battery, charger and rack. That's 5p10s of 3200mah Samsung cells making a 16ah 36v pack Also a upgraded best tech bms with 30a constant and a much higher burst (can t recall what) With a one year gauranteee. Every cell individually tested and then pack tested (internal resistance and capacity matched) Seems very good for what you get. To recell my old dolphin case wasn't a whole lot cheaper
December 8, 201510 yr Trex, I tried to buy one of those batteries from Woosh some weeks ago but they really weren't keen to sell me one - presumably as I dont have a Woosh bike, I ended up speaking for about 1/2hr to Jimmy from INSAT - BOY CAN HE TALK !!! I then.......eventually, purchased a battery from him as he really seemed to know his onions.
December 9, 201510 yr Called oxygen but only have 15.5ah at 260 without charger (silver fish style) Trex - hmmm, interesting Did you ring Andrew on his Oxydrive site? You might get a different answer from SYEBC.
December 9, 201510 yr Author In spoke to him but those 17ah have gone sadly Just 15.4ah at 260 quid left. Not ideal for me as silver fish style but even more crucially it uses 2200mah Samsung cells and 70 of them rather than 50. Fair bit heavier which matters to me as I carry my pack in a backpack on my mtb crank conversion
December 9, 201510 yr Author Trex, I tried to buy one of those batteries from Woosh some weeks ago but they really weren't keen to sell me one - presumably as I dont have a Woosh bike, I ended up speaking for about 1/2hr to Jimmy from INSAT - BOY CAN HE TALK !!! I then.......eventually, purchased a battery from him as he really seemed to know his onions. He sure can
December 9, 201510 yr I too had a chat with jimmy at insat yesterday a very nice person and a long talk re batteries cells etc it seemed it might be possible to recell my 10.4 ah (bottle battery with 50 Samsung high quality cells 3.2ah over the 36 ? existing. giving me 16 ah, so I thought good I will proceed and arranged for pick up of my existing battery. however when I looked at my battery 90mm dia 361 mm tall I could not see how more cells could actually fit in the case. so contacted jimmy again and the most cells that could fit my case was 40 also my existing battery still has some a bit of life left, not sure if there dolphin battery fits in my frame. so i meekly asked if i could cancel recelling /ups pick etc and this was ok a very nice company to deal with
December 9, 201510 yr Author That's really good to know I'm leaning further and further towards Jimmy Decision on Friday (when the required filthy lucre hits my account !)
December 9, 201510 yr After today's ride I may need to speak to Jimmy sooner then later, one of my 09's only managed 23 miles. On charge at the mo at some stage will have to open and check cell readings.
December 10, 201510 yr Author After today's ride I may need to speak to Jimmy sooner then later, one of my 09's only managed 23 miles. On charge at the mo at some stage will have to open and check cell readings. Interesting, my 09 generic Chinese celled pack is also suffering Fine using it with a 350w bpm2 but gets warm when using with the gsm I do wonder whether, unrestricted, if the kit draws a heck of a lot more than 18a. My battery from bms ought to manage 20a constant but.. I just wonder wether gsm really needs a 30a battery(when unrestricted) ? To avoid damaging cells.
