Hi James
Very sorry indeed to hear that you are so dissatisfied with the service you have received from us.
Clearly you are very upset and angry.
Our records show that you purchased the kit last February for £495.
You asked for a new charger in April, suspecting it may be faulty. We sent one to you straight away. In June you asked for a new controller, which you also suspected was faulty and which we sent. You fitted the new controller and then returned the old to us (thankyou). You reported the controller swap made no difference and the old controller, though with wires cut on return, tested good. You seemed happy that the problem was resolved.
You then reported your battery had broken and asked we send another, which the workshop team immediately agreed to do.
However, I decided to give you a call to find out a little more about the circumstances and decided after that call not to issue a brand new battery to you as I felt your description of how you use your bike and the road conditions you described contributed to the cause of the damage.
I did offer to repair the damage and you agreed to send the battery to us..
We made the repair and charged you £20 for the return postage.
Since then we have heard nothing more from you until discovering this thread this morning.
I am a little worried that leaving your battery uncharged for so long may be an issue. If you check ours (and others) battery care advice you should see that it is very important to regularly charge any lithium battery.
As others have said there will also be a temperature effect during the winter months compared to last July.
Winter tyres will also dramatically reduce range.
I am quite happy to take a look at the battery for you.
If you would kindly phone or email us we can arrange to receive the battery, test and measure it, and report back to you.
Kind regards
