Battery for Devron 28120 E Bike
Murph
13
Blimey, never expected that, I wonder why it's so expensive. It does look like it may well be the right battery though, with the four off-set connectors.
> If you weren't already wishing you'd passed on buying this bike, I'll bet you are now!
Too true. Mind you I haven't given up yet; I'll take the battery mounting apart and see what else that may tell us.
Do we know what the other two connectors are for? Temperature monitoring perhaps?
- Mike
cyclebuddy
1,644
773
Beds & Norfolk
Cost: It says 14.5Ah Panasonic cells. Even so, the whole bike is only 1300 euros.
I've never seen a four-pin connector on a Phylion pack until I just went looking for it (I wasn't even aware there was a revised SF-03 design). The 6-pin wiring config is above; 4-pins? Who knows. That it has a smart BMS doesn't mean the bike is using comms/those extra pins.
2022 model Bike link
Battery link
matthewslack
2,016
1,441
So any generic 36V battery will work, if you can't get identical shape/mount then get creative with a mounting solution. The electrical side just needs those red and black wires connecting between new battery mount and controller.
Murph
13
Excellent, just had a look on ebay and it would appear that I can get a 36V battery and charger for about £225.
Have to chack the fit first, obviously.
- Mike
cyclebuddy
1,644
773
Beds & Norfolk
I'm just wondering if this clone from Yose would fit? The connection block and case profile looks about right to me. 36v/13Ah, £177 inc. charger here.
50338
Murph
13
Gosh, that looks like it is exactly the same. I have emailed Yosepower and asked them about it.
- Mike
cyclebuddy
1,644
773
Beds & Norfolk
The Yose Clone battery I linked is described as "Rear Battery for Stella Bike".
If you check the images for the original Phylion/Joycube battery I linked in post #22, you'll find this:
50353
I'd be pretty sure the Yose clone version will fit/work. The Yose clone even claims a Smart BMS (as an original battery has, even though your bike isn't using those features/hasn't got those pins connected).
Murph
13
It's arrived!
I hope to be doing some pedelecing soon.
(There was no duty nor any VAT to pay).
- Mike
