Most chargers are set to 42v (4.2v per cell). Most BMSs have bleed resistors on each cell. The resistors are switched on at a voltage slightly below 4.2v, so they slightly slow down the charging of the highest cells while still allowing the lower ones to charge at the full rate. When the first cell reaches 4.2v, the BMS switches off all charging, but the bleed resistors stay on until the individual cells drain down to about 4.1v. That's generally how BMSs manage balancing, which sorts out minor differences, but id the cell voltages are totally out of balance, it's not enoght. The same principle applies to LiFePO4, but the cell voltages are lower
