C
Cyclezee
Don't worry CWAH, you are on my list
As I said previously, I will let everyone know when they are in stock.
The question is will it fit your motor axle cwah. What motor do you have and what is the thickness of the axle measured at the flats? The set is adaptable to fit the majority of applications.Thanks John. I'm so impatient lol.
Do you know if it would fit my brompton rear dropout?
Sorry cwah, I find it difficult to keep up, maybe it is age relatedIt's a standard 10mm axle so it shouldn't be a problem for that. I was mostly wondering about the brompton.£750 is a bit high for torque arms gonna wait a little lol
I wish we had a specific "only joking" smilie.I think it's me being not clear
I plan to fit this motor on the brompton:
http://conhismotor.com/ProductShow.asp?id=76
The axle diameter is 10mm.
Shemozzle, for now I'm only using this mini motor so that should be ok. Depending on how this motor perform I may get a bigger one (bpm or magic pie). I'll then have to consider stronger torque arm setup
I know. But that's fine because it's made for 24V and I overvolt it to 74V. If that's not enough I can still increase the voltageIf you read the page from your link cwah it says:
"we don't recommend use 16",18", because speed is too slowly"
Whoops, that'll teach me to not to skim postsI think John said when he came back from China.
Regards
Jerry
