that is usually an expensive mistake. It's done so we can't go back there.Understand. Actually i bought motor without rim.
SWX02 data for your reference:
flange diameter: 145mm
flange spacing: 42.5mm
spokes: 36
axle length: 135mm
spokes: 13 gauge
You need:
1. count the number of spokes on the old rim
2. measure the width of the rim
3. remove the tyre, inner tube and rim tape to check the state of the rim. Run your fingers on the inside of the rim looking for defects. Make sure that everything you are going to re-use is going to be in good condition. You don't want an avoidable puncture later.
Post some pictures. I need to know if your rim has double wall. The new spokes have 2.3mm diameter and use 4mm nipples. They should be OK with the old rim but still should check the diameter of your current spokes. Test some nipples just to make sure that they are going to be easy to remove too.
Online Spoke Calculator {Hub: custom / Rim: 700DM / Cross: 1} (ebikes.ca)
