BAFANG BBSO2 MOTOR PROBLEM
brianw
63
85
If he connected series instead of parallel or if he connected with reverse polarity, the capacitor on the controller would blow - normally with a bit of a bang and some horrible smoke, so it's pretty obvious at the time. You should be able to see that when you take the controller off. The components are potted in silicon, but I think you'll still see and smell evidence of it.
Controller is the pod behind the chainwheel that's held on with three screws.
Thanks d8
I'll let you know when it's off
brianw
63
85
Controller off, does'nt smell too fried
Have a look at these
brianw
63
85
wheeliepete
2,047
757
Devon
That capacitor dosn't look very well. (Black thing with green top). Looks like it has burst at the top, hence the brown mess around it.
wheeliepete
2,047
757
Devon
Def. looking like overvolting is the cause of the failure. Nothing else would cause that damage except reverse polarity and it would also explain the blown LCD. Two 37v batteries in series = 74v POP!!:eek:
8,594
Replacement controller but will happen again if over volted or polarity isn't right.
wheeliepete
2,047
757
Devon
What's my next move?
Any point testing
I would carefully peel back the green label on the cap and check for damage. Then show it to the new owner and try to explain how this has occurred.
I think you have established what is damaged by your testing with your LCD and wiring harness, but it may be worth inspecting the motor for overheating damage before you buy a new controller and LCD.
brianw
63
85
Could you see the white powder on the casing from my pic, it seems to be in a strange place if things have blown inside the green label.
wheeliepete
2,047
757
Devon
White powder is aluminium oxide caused by water/moisture ingress into casing, not enough to worry about.
brianw
63
85
Morning Wheelie
Tried to remove motor housing but after extracting about 15 mm felt resistance, did'nt force any further
Any advice?
The brown oil is what's inside the capacitor. It comes out when they blow.
brianw
63
85
Any idea how much replacement controller is?
I've priced LCD at £60 so controller is likely £100 plus so not being sure motor is not fried as well, it is looking like a complete kit at £387 maybe safer way to go.
Would you agree?
5,786
So far I have only let my GF ride the GSM powered bike back from the supermarket - it is all downhill. She keeps asking me "When can I ride it to work?" and I keep playing for time... Cadence is so important on mid drives you really need to be in the right gear on steep hills and I can imagine the sheer power of the BBSHD could lead someone to believe it can climb anything in top gear. Well it obviously can't...
I also think you are very brave selling LiPo packs to complete newbies. Do they have some R/C experience?
brianw
63
85
Yes with hindsight I did'nt emphasize the risk of making the wrong connections to multiple sets of batteries.
Charging with my GT Power is pretty fool proof if he does'nt short the batteries and they won't be on the bike.
But absolutely right about the cadence but in this case I don't think that did the damage
16,976
yes, it is a big point concerning not so much the BBS01 because it does not have huge power but totally when it is the BBS02 and the HD.
