Yes, it looks like that box has the controller in it, but not much chance of finding out the amps from it.
I havent opened that up yet. If I do what would I need to look for?Yes, it looks like that box has the controller in it, but not much chance of finding out the amps from it.
Unfortunately, that doesn't mean anything. By 7A battery, they mean 7AH. 200w is equally meaningless because the Powabyke Euro is also rated at 200w. It's a really good climber, and I believe it has a 20 amp controller. Your bike has the same motor. 20amps at 36v = about 750W - or at least 400w output power.From info found online I believe it is 200w
7 speed folding bike
It suggests that it has a 200w front hub motor.
Assuming that the controller is working ok, and that it is a battery issue, what options does it give me?
You will need to repeat the process again, and take it out for a ride to put some loading on the batteries before you recheckI think I will try charging those two with the ctek type charger to see if they can be recovered.
Crossed fingers and all that
Sounds fair. Will do, My nephew is coming round in the next few days. Gives me a chance to charge them all with the CTEK to hopefully rectify the situation. But if not, at least to narrow the area of fault.You will need to repeat the process again, and take it out for a ride to put some loading on the batteries before you recheck
What is it that could make it more powerful? Have you upgraded it to its limits or is there something else you could have done that would have made it better?D8veh's probably right (usually is!) in recommending a beefy battery.
My missus has a powabyke x6, with a 250w brushed motor & it sucks some serious power from the battery going uphill: I replaced her battery with a 10ah flatpack from cyclezee (regarded as tough batteries) & even that sags significantly on a hill.
Nothing like that obvious on mineI know on my old bike, the batteries had a sticker with the date on
Maybe this article will give you some insight into the differences between Lithium v SLAWhat is it that could make it more powerful? Have you upgraded it to its limits or is there something else you could have done that would have made it better?
