Are trikes allowed to be dIscussed.
BrianP
80
33
Thanks D8ve, my mechanical skills are good. Used to building framesets up, just terrible electrical skills.
8,572
Electrically they are simple all moulded plug and play fittings, the onlt issue may be hiding some wiring if its a bit too long.
BrianP
80
33
Very excited. I have been looking, hoping to find a nice trike for sale. Well tomorrow I have a HP Velotechnik Scorpion FX arriving!
Being designed to fold small, it will still fit inside my wife's UP if I need a lift home as I recover my strength after treatment. Thanks to your help I also know how to approach addIng electric assist.
Brian
timidtom
757
175
Cheshire
GambiaGOES.blogspot.com
Brian
Hi: 'fold small' - how small is small, please?
Best wishes,
Tom
5,786
Best wishes,
Tom
The Gekko will go in the space at the bottom of my stairs where my trailer is parked 107 × 83 × 58 cm, the Scorpion is slightly bigger 90 × 83 × 63 cm <- it is the 5 extra cm "thickness" which counts if you can slide it in or not.
D8ve
2,142
1,294
Bristol
You will need extension cables for the speed sensor at least one and probibaly to to take off the rear wheel.
Reactions: timidtom
grldtnr
627
288
south east Essex
That velotecnic looks good, is it an import, or did you source it at home,where ever home is?
Look forward to learn how you get on with conversion, if you using it manually, I.e. old skool pedalling, bear in mind recumbent use muscles in a different way than solo upright bikes, once you get the knack,they are tremendous fun!
