8fun crank drive kit
st1vo
26
Either that or look ahead and stop pedalling before you need to stop!!
So should I go for 36v250w, 48v250w, 36v350w, 48v350w, or 48v750w...
Has anyone tried any different models??
I think the 36v250w can only handle 15A, is this enough??
Ideally I want to build a brutish off-road beast!!! :))
shemozzle999
2,826
686
Then I suggest you start another thread in the appropriate section.
shemozzle999
2,826
686
Sorry, I thought this section was about the 8fun crank drive kit!!
Hi st1vo,
this section is for:
Forum: Electric Bicycles
General discussion about electric bikes, e-bikes, pedelecs, pedal-assist. The current UK law states maximum power output of 200 watts (250w Europe, yes we are in Europe!) and a motor that should not propel the e-bike past 15mph. Please ensure all conversations respect the current (albeit slightly foggy) legislation.
If you want to discuss off road bikes with or without 8fun crank drive kits then use this one:
Forum: UK off-road, S Pedelecs & overseas
Any conversations regarding use of electric bikes on private land, outside Europe and discussing motor propulsion beyond 15mph or maximum power outputs above 250w, please keep conversations in here.
I hope that helps.
What's the matter with you complaining whenever anybody types a number bigger thsn 250. He's asking if the 250w is enough. You should answer yes or no and justify your answer.
st1vo
26
OK, I'll re-word my post...
Is the 36v250w version enough??!
I'm wondering if anyone has experience of the differing power options??
shemozzle999
2,826
686
What's the matter with you complaining whenever anybody types a number bigger thsn 250. He's asking if the 250w is enough. You should answer yes or now and justify your answer.
jackhandy
1,820
323
the Cornish Alps
Just as well shut-down all the other sections & just have the Offroad one then.
Ho - Hum...
st1vo
26
Do you want to build a brutish beast with a 250w motor, or would you like me to recommend to you some even more brutish ones?
I think I'd like to explore the more brutish options... but maybe not in this thread!!
Don't want to annoy anyone!!
I'd like a cool lcd display too showing everything I can think of!!
fishingpaul
874
86
Keep it on here the mainstream thread as some of us would like too see what you try or eventually buy,apart from the boring brigade who will probably die before they have lived,even flecc used to ride a 22mph electric bike they are great fun, in my opinion you get far more smiles per mile on a more powerful bike.
I
The Cycle Analyst is pretty good, but you'd be doubling up on all the stuff on the 8Fun LCD. It not only gives all the electrical and battery info, you can use it to control parameters like maximum current/speed/temperature/etc, plus you can put a profile on the throttle response and do loads of other things.
The Speedict Mercury is also good for showing battery info. It also logs your journey via GPS, so you can see how much power/speed you had up your favourite hill. It transmits to an Android phone via bluetooth.
shemozzle999
2,826
686
Hi st1vo.
Just to reassure you that I am not annoyed by your posts.
As a new member I just wanted to advise you of new forum guidelines.
If you wish to pursue your own thread based on what you ideally want to achieve then the section mentioned would be the correct place to start it.
st1vo
26
Fair enough... I've started my own thread on my build plan and would appreciate any input b4 I blow £750
shemozzle999
2,826
686
It seems as if there still a lot of confusion over the different types of motor available due to a lack of information direct from the manufacturer.
8fun the European distributor has removed all reference to the product and there is only a compilation of broken information circulating around the web.
CoachMark
16
The Yorkshire Alps
I'm a new member and, based on my interpretation of the advice I've had so far, am interested in converting my bike (photo attached) with a crank drive.
I've not had the chance to try one yet but wondered what the forum thought about the 8Fun's power to get my 85Kg up our steep Yorkshire hills?
big_gems
22
What's the best 48v frame mounted battery to go with the 750watt unit.
Sent from my GT-I9300 using Tapatalk
