Or maybe just the sensor glued to something solid and pivotable with cable ties which makes it look like this.
https://goo.gl/images/imoXG2
That is sensibleOr maybe just the sensor glued to something solid and pivotable with cable ties which makes it look like this.
Thanks I had read that elsewhere from you and already tested the directionWhatever you do, make sure that you test it first to figure out which way up the magnets go and which side's of the bike it'll work. It would be a bit annoying to have everything nicely glued to find that it only works when you pedal backwards.
If I can save one person, it's worth all the efort.Thanks I had read that elsewhere from you and already tested the direction![]()
Do you remember which settings you had to change? I saw that one was magnets x reduction ratio but I have no idea what that is.He has a KT controller and LCD-3 I think?
So yes I did try: went from an 8 magnet disk to a 12 magnet one and I changed the settings to make it work smoother. It worked with 8 magnets but setting the number to 12 made startup much smoother.
That's P1. You don't need to set that unless your motor runs rough.Do you remember which settings you had to change? I saw that one was magnets x reduction ratio but I have no idea what that is.
Thanks![]()
PAS disk choice is C1.Do you remember which settings you had to change? I saw that one was magnets x reduction ratio but I have no idea what that is.
Thanks![]()
I was using similar mathematics when cycling home and wondering whether this will play out correctly.It's very easy to calculate range because the power from the battery is constant if you only ride on one level. Level 2 =170W, so 3 hours =510Wh. Average speed of 30km/h means 90km minimum from a 500Wh battery. In practice, a 500Wh battery probably gives 20% less charge, but you don't use any power when freewheeling and the motor limits power a bit as it approaches maximum speed, so that probably equalises the 20% capacity shortfall.
The best way to know how much you have left is to use a Watt meter between the battery and the controller. The lights will show voltage and as you know the discharge curve of Li-Ion is quite flat - you have 36v for quite a long time. Then it falls away sharply.I was using similar mathematics when cycling home and wondering whether this will play out correctly.
Given that I asked for the 14.5ah battery with integrated controller (and they only advertise 11.5ah) I did wonder whether I actually have what I requested.
Also, the battery case has a small that has 4 lights on. It showed 3 green and 1 red when the charged has finished yet it also showed 3 green when the lcd3 3 was only showing 1 bar left after my first ride with the thumb throttle last week. Does the battery indicator on the case actually work?
I have been away for a few days exploring Australia. The LCD says 50.1 which suggests that I have more than bf my juice left. ResultThe LCD will show voltage if you short press the power button twice. That's actual voltage. 54.6v is absolutely full. It drops very quickly to around 53.3v, then goes down more or less linearly to 43v, then starts to accelerate downwards, so you can say the bulk of the charge is between 53v and 43v. Each 1v change is 10% of your battery and 48v is half-full.
