Just disconnect the one you want to replace. You only need a cut-off on the back brake.
Change the front brake to whatever you want, and you still have a switch on the back one, so the motor cuts when you apply the back brake, but not the front one. You never use the front on its own, so it's not a problem.
Both brakes have switches, right?So they can put front hydraulic on and still have the front brake lever cutting out the motor? I'm getting confused!
