Yosepower hub kits.
8,843
35E or GA both same capacity, GA the better cell.
Reactions: wheeliepete
PC2017
1,338
338
Scunthorpe
Postage looks very reasonable
I confess I didn't read the ebay listing but your instincts are spot on, just got an email 10 euros FedEx - bargain...
From what I skimmed over they limit stock/storage by making them to order...
I do think we may have found my future battery maker!:cool:
GA the better cell.
There's def not much in price difference...So how do we gauge the "better" cell, is it from experience, the data sheet, general consensus or something entirely different?
wheeliepete
2,047
757
Devon
Looks like you have until the 3rd December to guarantee pre xmas delivery. I think the GA cell is so well established as a go for cell, that it is very hard to overlook.
PC2017
1,338
338
Scunthorpe
pre xmas delivery.
Am not bothered about getting it before xmas, I need slightly warmer days before I consider buying anything, easier to start on the full project when the sun shines - Yep I think I will go for the GA cell - I think that wraps up (pun) the research for now....
Len2000
12
Some batteries can be tricky to remove from the rack mine was all them moons ago.... the lock should be up inside the battery case not so you can feel it or see it from underneath, depending on the battery style you'll need to hold the rack with one hand and slide the battery up, it's a bit hard to explain but keep trying... + for safety I would use the brake sensors if its your 1st ebike or YOSE do sell just the sensor that fits under your own brakes otherwise the kit will work without them connected!
Thanks PC2017..helpful advice
Reactions: PC2017
PC2017
1,338
338
Scunthorpe
PC2017
1,338
338
Scunthorpe
sliding/adjustable bottle mount for downtube
Try looking through this thread there might be some info that'll help, I can't remember what pages though sorry.
PC2017
1,338
338
Scunthorpe
Any thoughts on 48v through my front 250w YOSE motor...
Good idea? - bad idea?
8,843
The Yose front hubs don't have the torque in NM of the rears so maybe a bit weedier but no reason not to go 48v just limit the amps to 12 to start with to see how it goes. You will need a new controller (suggest dual 36/48v 15a kt ) and change connectors on peripheral's.
Currently you are prob seeing 430/440w max at the wheel ?
With 48v @ 12a you would see about 450/460w max at the wheel, though with 15a controller can tweak it up to 576w.​
PC2017
1,338
338
Scunthorpe
Yep strangely though, I forgot to mention this a while back and is the reason for the 48v question - with the YOSE LCD3 it cuts off bang at 15.4mph 440w(speed limit set to max 40 kph or 50 I can't rem) but, and I never did run it with the dillenger LCD3 as I wanted it to record the OD, now it does not cut off at 15.4 and seems to just drop off at 17.4mph however the two LCD's were run off the same controller(dillenger)
Yer cool - I was thinking about just getting the battery and controller, then buying the rear 48v later when I have accumulated some more funds... then thinking about it brings me to more crazy questions, without buying lots of different controllers is there a way of reducing the amps from one controller?
8,843
LCD3 allows you to reduce amps using C5 parameter by up to -5a on older s/w versions or newer s/w versions by a % rate up to 50%.
Controller needs to be rated to handle 48v, most 36v controllers only have 50v caps so will not handle 48v. The dual voltage and true 48v controllers will have 63v rated caps.
5,786
Should read: "Will not handle a 48v battery hot off the charger", mine handles LiPo 12S charged to 49.8 peak just fine.
PC2017
1,338
338
Scunthorpe
Cool i'l check that C5 out - I was planning on getting a 48v controller but the Julet after market 2 on topbikekit only come as 15amp and 22amp max rated.
I never thought of that - sweet - it'll still blow up knowing my luck!
PC2017
1,338
338
Scunthorpe
So if I got the 22a I would be looking at setting C5=03 for 11a or C5=04 for 14.66a thats a massive 700+ watts:eek:
@11a that would bring the 250w inline with my 350w speed wise(ish)
So why does the manual say 01 & 02 are "undefined"
5,786
Probably left for OEM bike builders so they can set their value(s) there.
8,843
Quite right for 12s for someone like your self or I , who understand and can set max cell to 41.5v each but 36v/50v caps controller no use at all for 48v/13s battery as the max volts per cell would be a tad under storage charge of 38.5v.
8,843
Shame they only do KT/Hailong controller and not the standard controller in Julet as well.
