Yose Power Hub- need a new rim!
3,349
Are these any good for you?
Able to take tyres up to 65mm.
The one reviewer says he used one to fit an Alphine hub on a Tern D8 (I know nothing about Tern's!). Also available in 36 spoke version.
Ryde were formerly Rigida, so decent quality.
Thanks, yes that does help. I have 28H and 32H rear hubs, 18H and 28H front hubs - 28H are Tern, the others are original Dahon Kinetix. I'll have to see what 74mm front hubs are available from Shimano and others. I should buy a front rim plus other bits soon before I need them - managed to buy an entire spare new rear wheel on for less than the price of any of those rims late last year, still haven't got around to installing it; spokes might be rubbish, it's bound to need truing (they all have so far). I think the widest tyre I can fit on my frame is not much wider than 2.125", wider may result in woolly handling anyway?
You guys always make things so difficult and expensive. I've never used any rims other than the cheapest ones I can find on Ebay and Amazon. I have never had a single issue with any of them - no corrosion, no spokes coming loose, no denting , no cracking, no truing necessary. That's building always with 14g spokes, if that makes a difference. I always ride up and down curbs and on rough trails. I've also hit many potholes.
Be careful of rims with eyelets in the holes, especially if you plan to use 13g spokes, because they tend to hold the spokes at right angles to the rim. Either use 14g spokes and nipples or don't have eyelets.
Thanks, very useful hearing your experienced perspective regarding the cheapos and eyelets. I'l have another good look around on the internet's Chinatown.
3,349
32H hubs for 74mm and rim brake are really rare. So far, I've found this one. They probably don't deliver to the UK.
Also this generatively rolling dynamo hub:
Wayners
488
102
55
Gloucester
I need to fit a new rim to my front yose hub wheel.
I unsure if it's something I can tackle or if I should just find a local shop to do it?
Problem is I've been running rim brakes so I'm going to upgrade to discs. Reading through it seems there is lots to consider when buying a rim and getting the correct spokes.
I wonder if easier to buy a new hub wheel?
thelarkbox
1,526
477
oxon
fitting and trueing spokes in a new rim is a doddle if your methodical about it, getting the right spoke size is the main hurdle, I got that wrong a few times so by the time the right size arrived I was well practiced and it took no time..
useing onlne spoke calculators might be a good idea..
using upturned front forks and cable ties snipped to size makes a diy trueing frame that just needs an upturned bucket for a stool to sit on while you get the wheel round..
youtube fed me all i needed from suggesting diy hub stands to get started to stressing the wheel when 'first done' and retesting spoke tension listening for the same spoke twangs..
btw all spoke sets i got had EXACTLY 36x nipples be mindful not to loose any
matthewslack
2,397
1,602
It is one of the great learning experiences with an ebike. You only need to do one and you'll have all the learning, and every step of the way there are plenty of people here who can help.
First find a rim, then calculate the spoke length required, and so on. The build is not hard, just a bit slow the first time.
Post details of the existing motor, rim etc. to get the conversation started.
30,787
I absolutely agree with cadence, steel rims and rim brakes are a lethal combination. (How did our parents ever survive long enough for us to exist?)
We rode at much slower speeds, most cycling was typically at 10 mph, none of today's barmy belting around helmeted at 20 mph or more.
Reactions: thelarkbox and sjpt
Wayners
488
102
55
Gloucester
Update.
Ordered a new wheel from @Woosh.Andy was helpful.
Should go straight on then I can repair the current yose wheel which will be a spare.
Will update my progress for interest
Wayners
488
102
55
Gloucester
Here is a picture of my current rim with sizes. Any guidance on what rim is required would be appreciated.
26inch wheel.
599x19
62099
2,829
The critical measurement for a 26" wheel is the 559 (mm bead diameter)
The choice of width depends on how wide a tyre you want to fit, but not so much need for exact match.
For example see the table in https://www.schwalbe.com/en/technology-faq/tire-dimensions/
Remember the tyre width will be limited by the frame clearance as well.
Reactions: Wayners
Wayners
488
102
55
Gloucester
Update.
The woosh xf07 wheel fits and runs fine on standard yose controller however, the yose wheel comes with a long 9 pin cable and the xf07 is short. I've ordered a 9 pin 1.6m extension cable which will resolve the issue.
I'll then be available to swap the yose wheel rim.
8,740
The tyre will still fit th XF07 rim , all it means is as it is wider one can fit a wider tyre for a bit more comfort by using slightly less PSI.
Cadence
303
221
I'm running 26" x 2" Schwalbe Big Apple tyres on one of my bikes that has a Yosepower rim on the rear and a 19mm front rim. Pressures for both at 35psi and not had any problems in over 500miles. Easily the most comfortable bike I've ever ridden.
Cadence
303
221
My rim pushed out on the rim manufacturering joint having rubbed thin with brake pads I think
Yes, I am consciously aware that fitting a hub motor accelerates rim wear when using rim brakes. Unfortunately the bike I mentioned above is a 90's Giant steel framed MTB so I'm stuck with v-brakes. I deliberately use the front brake only most of the time as it's easier to replace the front wheel than re-rim the motor-fitted rear.
I was one of those that feared using the front brake alone would launch me over the bars until I read about efficient braking on the late, great Sheldon Brown's website:-
A very useful website, although a little out of date on some aspects.
(Edit. Just re-read your posts and realised you have a front motor hub, so my comments on front braking won't really help you. Fortunately my other bike has a rear mount for a disc brake, so I've fitted new forks, new disc mount front wheel and Zoom hydraulic brakes. The difference is amazing and no rim wear of course. I still favour front-biased braking though!)
