Would fast charging make much difference?
I like this idea by [mention=35169]mr_ed[/mention] that I've lifted from another thread:
"Similarly with fast-charging.... I don't think it has to shorten battery life or cause fires. It works ok for Tesla where they can recharge something like 50% in 20 minutes. If I could do that on my e-bike I could carry a much smaller battery and go on much longer leisure/touring rides without having to use hotels to charge overnight. Again, I think currently its a case of e-bike batteries & chargers not being designed for fast charging [...]"
I can picture coffee and cake at a bike friendly cafe with a fast charging connector on an outside wall. But would fast charging see widespread and/or regular use or is it too niche to count? Would it actually make a difference?
  • Replies 65
  • Views 23.6k
The battery could then sink into a sand pit deep underground via an elevator, in case it bursts into flames burning your croissant and evaporating your coffee. This could work ok, but if the sand pit isn't sandy enough, the fire could ignite a nearby coal seam burning your town from beneath, with all the EVs exploding to help out.
Insurers will hate it. Seems they hate us already.
Edited by guerney
Needs some numbers to illustrate.
I use three different effective charging rates, depending on circumstances, and the fastest of them gives me 80 miles per day capability with touring gear, in the winter.
Slow: standard Shimano 1.8A charger. No use except at home.
Medium: Shimano 4.6A charger. Puts one bar out of five into the battery in 25 minutes (418Wh).
Fast: Two batteries, two 4.6A chargers, total 9.2A.
Take an hour for lunch in a cafe, and an hour in a pub for dinner, that's 18.2Ah or 655Wh charging per day.
If you have a 625 or 750Wh battery then for a day ride you probably don't need it. But a couple of added bars at lunchtime is very useful for the rest of us.
Is there a map of ebike battery friendly cafes and pubs? If they're less than 40 miles apart all over the country, I could camp out and travel anywhere for the price of coffees, croissants, pies and beer... if I bought a fast charging battery and fast charger. Perhaps such a map could spark a national trend? Eat Out To Camp Out And Pedelec About.
Edited by guerney
There'd be an online zap map for low power (ebikes, trikes and mobility scooters). Each charging point could display addresses of other nearby points, although that's not much help without a satnav.
A single 2A charger adds only 9 miles of range each hour, so adding 80 miles in 2 hours is good going. Is this something you'd rely upon if you had a new 400Wh Shimano battery?
But it only takes one cafe manager/owner to start charging £££s for the privilege of connecting to the power once everyone has invested in low mass batteries with high power input capacity bms systems for everyone to be scuppered with another leeching , ever increasing cost burdon.
With the aid of a motor, the added mass of upto 10kg+ for batteries is inconsequential to performance.. (if you allow the motor to pick up the slack.. )
I would rather pay a little more upfront and lug the power i need with me than rely on 3rd party providers motivated by profit.
Im sure faster charging will end up in the ebike world too but i hope not in the manner envisaged in this thread 'shudder!!'
With a 2A charger, it takes 10 hours to charge my 36V 19.2Ah battery from flat. It'd be nice if I could safely fast charge a 20Ah battery with 16A.... 4A per 5Ah module, by somehow isolating and charging each 5Ah module separately, reconnecting the modules when done. It'd be simpler carrying four 5Ah batteries and fast chargers between ebike charging friendly cafes and pubs.
I guess for most ebikers, fast charging isn't important because most journeys are short ie totalling <40 miles a day? Therefore manufacturers won't be bothering to develop ultra-fast charging ebike batteries for non-commercial use.
Edited by guerney
Bear in mind the 80 miles in 2 hours is because I am charging two batteries with two chargers, which means there is a spare battery as well as the two chargers to carry. About 5kg.
I would have no concerns on charge rate as these are official Shimano chargers, so designed for this use. 4.6A into the 418Wh / 11.6Ah battery is only 0.4C, so not 'fast' in the way an EV fast charger or phone fast charger is.
They do '80% in 30 minutes', which is 1.6C, 4 times as fast. Imagine that!
Differerence between fast charging a Tesla and a EAPC batteyr is night and day, the forma having 1000's of more amps to with stand any faster charge current .
So imagine that 0.8C isn't a stretch. For longevity you'd charge at home mostly and keep fast charging for further afield.
To visit somewhere 20 miles away averaging 10Wh/mile you'd need a 400Wh battery, or a 300Wh battery and a 25 minute top-up. 30 miles distant would need 75 minutes charging, a long lunch. 40 miles needs 2 charge stops, or about £420 for a second battery at Shimano rates.
If fast chargers were some 10 miles apart how many of us would use them?
Too true, but what if the online zap map shows popularity i.e. how much usage each charger gets? The moderately busy ones probably aren't expensive or broken. Usage fees are up to the provider, but with more customers being the reward in many cases there's an incentive not to charge.
As so often said, there's nothing new under Sun, see this link about such a company jointly created byPedelecs members Morphix (Paul) and funkylin (Linda) and financed by members, including myself:
https://www.pedelecs.co.uk/forum/threads/final-mile-ebike-solution.31003/page-2#post-433643
Brilliant flecc, thanks... last seen here around 2016, they / he'd been trying to develop the concept, company, website, app and recycling business... hmm.
Maybe it's good for this to resurface every few years, these days the tech side's easier and who knows, a CIC might entail less overhead. I wonder if Paul would put the website etc. on github for 'next time around'.
As your links and the responses here show it's the potential interest and these practicalities that make or break, so keep it coming.
Oh no! As usual it's a horrible data slurping app which requires the creation of an account, to enable even more data slurpage (to sell your data) before you are allowed to see what the yellow house icon means, after you search for a 3 pin charging facility on the Zap Map. I'm also annoyed that it's useful! For a particular 76 mile journey between a city an a town I'm considering ebiking regularly, there's a yellow house icon of currently undefined meaning (I haven't created a Zappo account) at the 36 mile mark. Perhaps I can ask the owner if I can sleep on their lawn for 10 hours to slow charge my 19.2Ah battery at 2A? There may be an additional sleeping bag lawn yawn/wear fee, but f they charge by the Kw, this could be cheaper than a AirBnB. Slow charging is all I'd trust with my particular somewhat aged battery composed of LG MH1 cells. After which I can spring up all vertical and jump on my ebike to pedal (max assisted, as usual) the remaining 40 miles, if my three year old battery still has the range.
Is Kings Lynn to John O Groats possible using yellow house icons, the ones with cheap lawns for hire?
Edited by guerney
How about this. Instead of eating a a big lunch, which will cause you to permanently carry extra weight, you carry a spare 10ah battery, which weighs only 2kg - approximately the same as the lunch and beer you'd be carrying in your stomach. When you get to the destination, you swap them over, or better still, use a 20ah battery.
"Supercapacitor-powered bikes like those from Ostrichoo offer a shorter range – about 70 kilometers per charge. However, this is offset by their rapid charging capability, with Ostrichoo claiming up to 80 percent charge in just eight minutes using specific chargers."
https://www.gizmochina.com/2023/12/28/ostrichoo-e-bike-ultra-fast-charging/
https://www.youtube.com/watch?v=_UUGiC6TqXc
The reason I originally asked this question/mused this future development is because I've been doing some longer trips on my e-bike whereby I need to use the power sparingly to get the range I desire, or plan accomodation where I can charge overnight.
I have a BBSHD with a 17.5Ah battery and a 2A charger. It'll do 50 miles fairly comfortably using a nice amount of power.
For one example, I cycled to Bath along the Kennet & Avon canal, this was 50 miles and I got the train back and then had enough power to cycle from the train station back home. I subsequently observed I could probably have found a 3-pin plug on the train and added 2-3Ah during the return journey, but no guarantees. I'd have happily locked the bike up for a couple of hours in Bath and recharged such that I could cycle full journey home.
For another example, I cycled from home to the Isle of Wight (~45 miles), recharged overnight in a Travelodge, then did a full lap (85 miles) of the Island, then recharged overnight again in the Travelodge, then cycled home again. I'd have rather camped but there would've been no charging available then. On the 85 mile day, I was really pushing it on range and so was using minimal power. I'd have been much happier if I could've fast charged 8Ah or so over lunch or a cake break. I did observe there were some 3 pin plugs available on the 1 hour ferry crossing.
I know I can buy a 10A charger, although possibly my battery (an EM3EV) wasn't really designed to be charged at that rate. I went in a few Cafes and possibly I could've asked them if it was ok to charge for a bit, but there's no guarantees they'd be happy with that.
....so that's what got me thinking. There's now a pretty amazing network of public fast chargers for cars. Cars and mobile phones can do something like 50% charge in 30 mins. It'd be great if an e-bike battery was developed that could fast charge and use the network of public car chargers.
There are some obvious physical constraints, like the charge connector that cars use is huge!
I'd not realised that Zap map also listed 3-pin plugs. That could be useful and a step in the right direction!
p.s. I'm not sure this is available even for motorbikes yet... A colleague of mine got a parking ticket for charging his electric motorbike in an 'electric cars only' parking space.
How can they give you 7km per charge when some of us can get that from our 20ah 48v batteries? Here's someone with actual practical experience. He got about 100 meters.
I will have a solution for you in a few months. I have been working on it for a while, but health issues and other projects have slowed progress. I gave a few clues a few months back, but I don't want to give full details until it's finished. In the meantime, get a bigger battery.
50 miles on 17.5Ah battery is pathetic. Do you pedal at all?
How long is a piece of string?
Its a BBSHD running at 52v, so it has the potential to run at over 1000W. I like that it is over-engineered for my use, although perhaps a bit heavier than is necessary. I've capped the current at 20A rather than the stock 28 (if I recall correctly). It's done 2500 miles with nothing other than a little grease...even the chain hasn't stretched!
On a short trip (20 miles or so) I'll tend to run at about 400W. For a long trip, I'll stick at about 200W and use the gears more and accept a slower speed on ascents. Last week I got 85 miles out of it doing this and still had 19% on the battery. The 52V BBSHD does behave a little unpredictably when the battery is running low... the controller can only sense the current voltage (whereas the BMS knows exactly how many Ahs have been consumed) and so as the voltage sags when you draw power then the motor controller thinks the battery is flat and starts to limit the power and intermittently cut it. So I've found if you run it below about 46V then it gets annoying.
I think 50 miles is pretty good! The bike weighs 25Kgs and I'm 75Kgs (well 80) and routes are fairly hilly.
