Hi there,
I've been reading the various forum posts with some interest, as I'm looking into acquiring an ebike later this spring or summer, but there's just so much to choose from!
I'm now beyond middle age (though hopefully not quite 'past it' yet!), and although a former non-comp/leisure cyclist and still reasonably physically fit and active, I'm not above seeking wise counsel from the more experienced pedelec riders and contributors in my quest to find the right bike. My area is undulating, with climbs of up to 150 metres in alt diff., though hardly 'Mt Ventoux' terrain. Much of the terrain I look forward to exploring is well tracked, though I don't really see myself as hopping stumps or boulders, as opposed to exploring the byways and less travelled tracks. Oh, and I'm around 100kg, and a 6 foot tall imperial/metric mix!
So far I've been tempted by the (Derby Cycle stablemetes) Kalkhoff Endeavour, Focus Aventura and Raleigh Stoker, all of which seem very similarly specced, albeit differently coloured; I understand the Kalkhoff has the better lights! These 3 models mentioned all use the Impulse 2.0 mid drive, which I understand to be a very competent motor, though I have yet to see or experience any of the main mid motor makes. I intend to use the bike for leisure trips, and off the public road, hence my interest in the S-pedelec versions, though I have also thought that should I wish to use the public roads at some future point, it might be more sensible to consider a 'compliant' type e-bike, and consider fitting a de-restrictor as and/or when required, should I feel the need for above 15mph assistance when back off the public highway - I think Im right in saying a de restrictor is available for the Impulse 2 motor? I should emphsise here - I don't feel I have any particular 'need for speed', just the option of having any assistance continue to around the 20mph level. So no BOSS system or Crystalyte 'mega hub' with a frameful or backpack full of LiPo cells, thanks!
One common feature of the Impulse drive offerings which attracts me is the possibility of using it in conjunction with the much vaunted and by all accounts worthy 17Ah battery, which is persuasive in terms of extending the range potential, which I do indeed give quite some weight to in my consideration, though of course this exteded range may be somewhat offset against increased speed somewhat, should the de-restrictor dongle be used for an off-the-public-road foray. One other bike I have been also considering has been the Univega Vision Impulse 1.0 e-MTB, with its upturned Impulse mid drive (a la Haibike's Bosch motor), which offers improved ground clearance, should I find myself off the beaten trail at some point, though I am not sure whether this model is available in the UK. I can imagine that with the 'magic stick' and the larger 17aH capacity battery I might be content toodling away at 17-19mph on the local tracks and unadopted roads. I wouldn't be averse to sourcing one of these on the continent if needs be, i.e. if it turns out that they are not available here in Blighty; the advantage as I see it with this latter offering (the Univega Vision) is that it is not an S pedelec, and is out-of-the-wrapper street-legal, but, assuming the Impulse 2 mid drive can be tuned, could still offer that extra couple of MPH without the cut out at 15 mph, coupled with the extra range afforded by the 17Ah battery, or (more properly) the range reduction, commensurate with any tuned mid drive motor, would be somewhat ameliorated by the greater battery capacity offered by the Impulse system, as opposed to others.
BUT - I also read great things about the compact yet powerful Panasonic Hub drive in terms of climbing ability, and then there's the Falco hub motor, which, though heavier for sure, also appeals, though I imagine that this latter might necessitate a bit more maintenance as regards spoke tensioning. At my time of life, I can understand the appeal/temptation of having a type of bike that permits one to take a 'breather' from pedalling on your journey without actually stopping and getting off, though I understand there are other bikes available with throttle and PAS! From what I can gather though, KTM do not offer anything other than a pedelec system with the panasonic hub. I do however like the idea of a lighter weight bike like the KTM P- Series, that is not going to be too demanding in terms of rider input should one run low on juice or have an e-glitch whilst out and about.
Oh, and the whisper about the new spec Ezee Raptor has not gone un-noticed either - very intriguing - might be hopping those rocks after all!
As said - still working it out!
