Well, I've managed the 1000 miles, in just over four months. This is the mileage I usually covered in six months on my normal bike, so it proves something. That 'something' is probably that it's a pleasure to ride, and easy to ride. Unless I've covered 20 to 30 miles, I feel okay when I get off. My age and condition account for any tiredness on the longer trips. I fitted a bracket to the handlebar stem to attach the wiring harness, as I'd seen on a Freego. This had the unintentioned consequence of making the riding position a lot more comfortable. I can think of only two problems so far. The first was a dodgy pedal. I fitted a spare pair I had, and dismantled the suspect one. I'm pretty sure there was one too many ball bearings in there. With one removed and reassembled, it seems okay. The other thing was the plastic tray the battery sits on. Part broke off, but this was replaced FOC within 24 hours by Woosh. While fitting it, I realised it was possible for water to enter around the 2-pin plug for the battery, which is a floating fit in the centre of the plate. I sealed this with some high tack silicone grease. Really good stuff for an electric bike! I bought mine from this
online plumbing supplier.
Well, while riding it, I've had time to form an opinion of my ideal Ebike. I like the battery in the centre, as it keeps the weight in the right place. 700C wheels may make it more free-moving, but I have not tried one. I do not need lots of gears for my use, as I'm usually in a low one to start off, or a high one once moving. I may consider a conversion when the warranty period expires. The Momentum Model T seems to have some good ideas, like the 2speed autochange hub. A thumb throttle would be better, then I can change the grips. The rigid forks and practical front rack on the Kudos Duke/Duchess are appealing. I would have to fit a front motor to enable me to change the gearing, but for use in built-up areas with no major hills, a 2 or 3 speed hub is definitely the best setup. The Sundowner was suggested to me by Hatti, but I have bad memories of hub gears slipping and the end result....... I get the impression that things have changed now with the technology available, but I don't like the battery high up and past the back axle line. All in all, a really good bike. I have looked at others on offer at 2 to 3 times the price, but they seem to be constructed using identical components, which does make me wonder about the price difference. I just hope Denwyn can find a bike that he can be as happy with as I am with this one! Oh, and one more thing. Someone on this forum commented that the long wheelbase because of the central battery, made the bike unwieldy. I cannot say I have noticed this, but it does give a smooth ride, much like the difference between a long and short wheelbase Landrover.
