max 25kg.What rating and bag fitting type is the rack on the FB?
Oh sweet thanks, i'll very lightly glue/tape it on next time, its good you have spares for everythingI'll put of of them in the post for you tomorrow.
there is a spoke key in the charger box. If it's only slightly out of true, you can use No 13 on the spoke key to true the wheel.Have noticed the front wheel is slightly out of true but none of the spokes feel loose, might take to a bike shop if it gets any worse.
not if it's the front wheel which is much less stressed.Is there any harm in riding it slightly out of true?
I do yes, despite them both being filled with slime. My rides aren't exactly smooth tarmac a lot of the time though. I'm not filling them every day, but about every 5 days or so back up to where they should be. I've noticed on one of the tyres, when I remove the pump nozzle, I hear air escape for a few seconds before it seals again which makes me think 1 or both valves might be leaking a bit.will do Volusia. Thank you for the feedback.
do you lose air from both innertubes?
Well I wouldn't mind a spare, but likely won't fit it until I get a puncture too large for the slime to fixwould you like me to send you a schwalbe innertube for the front wheel? It is known for good quality and you would help me to compare the performance of the schwalbe innertube against the Kenda's for the rate of air loss.
I take it these are Schrader valves, easy to test for leakage just dab a little bit of spit on the end of the valve and it's clear if it is leaking. As you have filled the tubes with slime yourself and thus changed the original spec do you think it's really fair to be comenting on it in a review thread, I certainly don't.I do yes, despite them both being filled with slime. My rides aren't exactly smooth tarmac a lot of the time though. I'm not filling them every day, but about every 5 days or so back up to where they should be. I've noticed on one of the tyres, when I remove the pump nozzle, I hear air escape for a few seconds before it seals again which makes me think 1 or both valves might be leaking a bit.
Got any tips for a good bike fit? I feel like I prefer the sat upright position but bikes aren't really designed for that other than those Dutch ones
Slime is designed to go in inner tubes, and I was unable to find a single case of it causing reduced pressure. Would kind of defeat the purpose of the well regarded product.I take it these are Schrader valves, easy to test for leakage just dab a little bit of spit on the end of the valve and it's clear if it is leaking. As you have filled the tubes with slime yourself and thus changed the original spec do you think it's really fair to be comenting on it in a review thread, I certainly don't.
