Yes, I think so too. The Big Bear has excellent acceleration.Big Bear still suits me better
sent via huawei P9
If you need to transport the Big Bear I can certainly recommend the Exodus towbar carrier. At £60 its a no-brainer - though you would need a towbar. I can also vouch for the Big Bear. It has taken me along some fairly rough routes and come out the other side unscathed.Unfortunately, it is a very heavy bike at around 26kgs so it isn't the easiest machine to manoeuvre on to high-mounted cycle carriers, even if the weight is within the permissible limit.
Tom
Gore TeX rain coat and leggings, wellys, thermal underwater, good gloves.I
Most hub drives are banfun? Can anyone tell me the crucial components for upgrading to make the bike as comfortable as possible?
Andy
sent via huawei P9
That'll be 250 watts Sir.Trex do you know the maximum output power of the big bear?
250w is the continuous power the maximum output will be different.Trex do you know the maximum output power of the big bear?
sent via huawei P9
Ive learnt so much here and now trying to give something back where I can. Thanks everyonethat's easy to calculate. Maximum current * battery voltage * motor efficiency.
Maximum current: 20A.
Maximum voltage: that depends on the state of charge of your battery. On a freshly charged battery, you have 41.5V, the voltage sag at 20A is about 1.5V, so maximum voltage is 40V for a full battery.
The maximum efficiency is 85%. That will drop significantly at very low RPM or very high RPM.
Assuming you ride on a flat road on a fully charged battery, you would get near maximum efficiency. The mechanical output is thus: 40V * 20A * 0.85 = 680W.
In practice, you get somewhere in the region of 550W to 680W because your battery voltage will drop a bit with the battery temperature and also, the efficiency drops a bit after 15mph.
It's still a lot more than smaller motors.
