Wiring issues
Herby
13
So presumably these 2 wires are connected in the julet socket and are supposed to be connected ?
3,538
One more time. The red wire is connected to the positive battery wire. It carries power up to the LCD for the LCD. When you switch on the LCD, a MOSFETis activated. It joins the red wire to the blue wire, so the power goes back down the blue wire for the controller. The LCD therefore switches on the controller as well as itself.
The MOSFET works like a relay or electronic switch with red one side and blue the other. When the switch is off, a very small amount of electric charge can leak through, like a water tap that doesn't seal properly.
Herby
13
I do understand about the red wire carrying a voltage to the lcd screen and making a connection with the blue when switched on. My issue at the moment is that the whole cable is removed from the bike and is sitting on me desk with no battery and no lcd screen attached yet the red and blue are showing they are connected ( no resistance ). This is why I thought the cable may be at fault. By the way battery terminal are just blades and look to be in good order.
Cheers for your input.
3,538
Can you please explain which measurement you did that brought you to the conclusion that they're connected?
Even if they were connected by a dead short, it would make no difference to the function of the bike, since they must be 100% connected during operation. The only effect would be that your battery would run down very slowly when switched off.
A short between the red or blue and any of the other wires would be serious or fatal for the electrical system, but not between red and blue.
As I said before, you can test the bike without the cable and without the LCD by shorting the red and blue wires on the controller. That would eliminate any problem in the LCD or cable.
Herby
13
Ok. So initially I thought the cable may have a wire that was broken because at the hinge in the frame the cable had been squashed. So I removed the cable completely from the bike, no battery and no screen or controller connected and using the multimeter I attached one probe to each of the 5 pin hole terminals in the julet connector and the other probe again in turn to each of the 5 wires in the flat connector. I was simply testing for continuity. This is where I then found that red and blue wires are are connected, somewhere inside the cable.
Herby
13
Just for the update. I sourced a similar cable but without the brakes wire. 5 pin flat at the controller end and 5 pin julet to the lcd. Before installing I did the same connectivity test and lo and behold, the red and blue are not connected at all! Installed the cable and the first thing I noticed was that the lcd power switch now works to turn the bike and the screen on and off. Test ride and everything works perfectly.
The absence of the brake sensor doesn't seem to affect the operation at all as the motor cuts out when you cease pedaling anyway.
So thanks everyone for your inputs.
