Windows 10
  • Start date
6,568
game over you need a new computer cpu is way to high thus why its so slow and takes forever to do anything.
more pages you open the worse it will get so not really worth upgrading the sheep as cpu way to slow.
D C
1,142
577
You appear to understand techy stuff so will put some trust in what you say.
Memory is at 51% and cpu is running up to 98%. Is there something I can do without upgrading cpu to make it more efficient ? Can I disable certain features ? I only use this for browsing and general internet use , no gaming or silly stuff like that, very little downloading .
Linux mint 17 would do all you need and much more, also Zorin which was mentioned earlier in this thread.
Both my laptop and desktop ran fine on W10 but after anniversary update the desktop wouldn't restart.
I don't give up easily but after several lengthy re-installations without improvement I went back to using Linux Mint and love it.
If you get to the point of deciding to buy a new computer, try installing a Linux system on your old one first and you may well be happy with it. It will be lightning fast and won't want to know what you had for breakfast.:)
Dave.
Geebee
1,256
227
Australia
Go to your settings button, under the windows button in the bottom left corner, hit the about tab and tell us what the CPU model is, then we can make an educated reply.
Most likely its just a windows or software glitch that may need a factory reset or better still wipe and reload windows from scratch.
Windows 10 works better with slow hardware than previous versions and will scale to your CPU and RAM, 4 GB is plenty for normal internet usage etc.
Use Chrome for browsing it is a lot better.
I play with Linux from time to time but I no longer find any speed advantage over win 10, last year I loaded 6 Linux versions (all GUI versions) and win 10 on an old laptop and none was particularly faster.
jcubbin
21
Liverpool
Nealh as others have said your CPU is very likely the problem with your machine. I notice you said it is a notebook and not a laptop so it is likely to have a very basic CPU which was only designed for low intensity tasks and now with the bloat that comes with Windows 10 it is struggling to cope.
It may be worth while making these adjustments that I show below to see if it speeds anything up at all although you do sacrifice the overall look of windows 10 as it gets rid of all the fancy shading of icons etc.
I tend to use this method on low spec laptops that we have at work.
Ok first go to control panel by typing it in to the search bar
find the "system" icon and click on it.
on the left hand side of this system page go to "advanced system settings"
Now go to the "advanced tab" and in performance click on settings
The original setting will be "let windows choose whats best for this computer" - change it to "adjust for best performance"
you can always change these settings back to the original if you are not happy with the look / feel of windows 10.
Reactions: Fordulike
8,593
Thanks very much chaps for all info, trying to digest it all.
Not looking to get rid just yet a sit takes me ages to get use to the bloody things.
Geebee done as you mentioned;
AMD A4-1200 APU with Radeon HD graphics 1.00ghz.
8,593
Thanks JC have done that will give it a try and see what happens.
6,568
8,593
Mega, so far so good and looking/feeling much better. Browsing is on the up and I now have 3 or 4 tabs going plus TM open clicking between them the CPU is coping, Task Manager shows fluctuating % use now ranging from 18 -98% :) :).
Geebee
1,256
227
Australia
It should do for the internet but it is the bottom of the barrel for CPU performance, it even makes the Atom CPU's look good :(
It will end up like the netbooks of old after 4 or so years they can now not even surf the net adequately.
8,593
By downloading Linux will it replace and wipe W10 or does it W10rmain loaded ?
Hard discs or solid state discs (SSDs) are very cheap now. It's normally very easy to remove your exising one, then you can plug in the new empty one. You can then download and install Linux to try it out.
You have to check your existing HD to see if it's SATA or the older IDE. most are SATA now. Here's a SATA SSD:
http://www.ebay.co.uk/itm/Kingston-SSDNow-V300-2-5-7-0mm-60GB-SATA-III-SSD-Solid-State-Drive-UK-DELIVERY-/111718826001?hash=item1a02f60011:g:iY0AAOSwBnVW9P8R
You can try out Linux by installing it on a memory stick and running it from there, but it's better to try a normal installation. If you don't like it, you can always put the SSD in an external caddy and use it for data sorage like an overgrown flash drive.
Fordulike
3,802
1,538
Great tip. Switched to best performance, and the only box I needed to turn back on was the 'smooth edges of screen fonts', otherwise text looked a bit blocky.
