The 201 RPM motor is a bit too slow. i think the 260 rpm one will be better even if you restrict the speed to 25 km/h.
You don't need to order the LCD, PAS and throttle because they're already included with the battery and controller. Look at the small picture under the battery. it shows everything that you get.
IIRC, that 17 amp controller gives you the opportunity to increase the current up to about 19 amps by software settings if you find that 17A is not enough.
