which kit
Wisper Bikes
6,319
2,283
70
Sevenoaks Kent
thanks, sorry to go on and on, just trying to get things straight in my head.....and for the german engineering as apposed to chineeeese?
any comments, though I appreciate its a volatile topic.
The wisper 806e is German, am I correct?
We made all Wisper bikes at MIFA in Germany two years ago. MIFA made the Smart Bike and Grace E bikes so we were quite confident they would be a good manufacturer. We could not have been more wrong! Hastily we moved back to Kunshan in China, which is gradually becoming the world ebike manufacturing centre of excellence. These guys are more innovative and really care about the business. Recently it has become cheaper to make e-bikes in Eastern Europe due to Chinese wages overtaking those nearer to home. We strongly believe that China is the best country to make our bikes.
All the best, David
poptop
75
9
72
think I am getting there, phew......looking like the wisper 806e with bigger battery is in the lead. Any comments Andy?
Wisper Bikes
6,319
2,283
70
Sevenoaks Kent
Aha, will you be having a larger bike with hub gears like the 705?
sent via huawei P9
No sorry Andy, we are staying put with a few (67) minor upgrades next year. This year we have been continuously out of stock and this we believe is the biggest problem we have in growing our business. The bikes are really good and work well. In 2017 we have one 40' high top container arriving in January then two more every month until May when we increase to three a month for the height of the season.
Our bikes are good, we now want to become one of the only Ebike suppliers not to run out of stock during the year!
All the best, David
Reactions: mike killay
d8veh i would love to see what you think would best suit the original poster,you seem to have been dragged away from the original post,leave the fighting to the people trying to sell their wares.
At only 75kg, Poptop has a very wide choice. That's the problem.
I weighed 100kg when I started ebiking, and we have a lot of steep hills around here. I started with a regular Bafang front hub-motor 36v battery and 15A controller. It changed my life and probably saved it too. All ebikes work, and it's not expensive or difficult to change bits to make them suit you better (bars, seat, gears, etc. I was happy with that original bike and bits of it (motor, controller, throttle, PAS) are still going after 6 years, though it did need a few minor fixes.
Here's the features I like to see in an ebike for normal riding on the road, like touring, shopping, visiting, etc:
1. Sinewave controller for smoothness and quietness
2. At least three levels of assist
3. Gearing suitable for pedalling to at least 20 mph. That means free-hub gears or a chainwheel at least 44 teeth (at least 50T with 20" wheels).
4. Disc brakes, preferably hydraulic. I would immediately upgrade cable disk brakes if I had no choice (£50).
5. Up-to-date cells. A 36v 12Ah battery should now weigh less than 3kg.
Now we get to the choice of crank vs hub-motor. For very long hills, say greater than a mile, a crank motor is probably better (OEM legal 250w 26" wheel bike). For everything else including bikes with smaller wheels, rear hub-motor, provided that the motor has a sensible winding speed. The problem is that different hub-motors have different winding speeds and the OEMs probably haven't a clue what theirs is, even though it's a significant characteristic.
Now we come to decision time. To answer the question in OP: Yes, a Bafang BBS01 will be suitable. They're easy to fit and you can choose whatever battery you want. Make sure you get a gear-change sensor. They're quite expensive, but they're worth it. Problem solved!
Originally, he wanted a folding bike. That's a bit more tricky because there's so many similar. I think that gearing is probably the most important if you want to ride any distance. After that, battery weight vs capacity. I don't like to recommend particular bikes except when people have special requirements that make a bike particularly suitable. I always go for the cheapest that meets my requirements, but I can fix and change things if I find something that bothers me.
Which bike should I get? That's the same as saying, "which car should I buy?" There's no answer. The more research you do, the harder is the choice. You just have to dive in, then learn from your experience.
trex
7,703
2,671
Something like the £749 Gale will do:
1. Sinewave controller for smoothness and quietness: checked
2. At least three levels of assist: checked
3. Gearing suitable for pedalling to at least 20 mph. That means free-hub gears or a chainwheel at least 44 teeth (at least 50T with 20" wheels): checked, the Gale has 50T chainring
4. Disc brakes, preferably hydraulic. I would immediately upgrade cable disk brakes if I had no choice (£50): the Gale has V-brakes.
5. Up-to-date cells. A 36v 12Ah battery should now weigh less than 3kg: checked. The Gale has 36V 13Ah.
you don't need to pay a lot for a 20" folding bike that fulfil these criteria. The two most expensive parts in an e-bike are the motor and the battery. Let's just concentrate on those two.
Andy88
747
135
69
Ayrshire
Nice Post.
If the hub is at the front then surely if its knackered you can just pull the wheel with motor out and throw a new one in? Cost for wheel and motor £100?
If hub motor at the back is it just as easy to replace?
sent via huawei P9
5,786
For a crank drive/mid motor 28"/700C wheel bike on hilly terrain a 42 tooth chainwheel is proving to be the best choice. I have a natural cadence of between 60 and 80 and am quite strong (for my age) and yet managed to find a slope where the original 46 tooth chainwheel was too big and stalled the motor.
For those looking for a bike with a mid drive for commuting or trekking I would suggest a Yamaha powered bike with a twin chainring setup. I am considering mounting a 48-36 double chainring and two speed derailleur on my GSM so would be changing the chainring for up hill and down hill and probably staying in the middle three gears on the back most of the time.
The people I see riding bosch powered bikes around here all seem to have a ridiculously slow cadence.
trex
7,703
2,671
replacing a motor wheel is dead easy, pull off the motor connector (behind the chainstay), loosen the two M10 wheel nuts. The old wheel comes off very much like a normal wheel.
Here is the motor wheel on the Gale:
You should zoom in to the all metal folding pedals on the picture.
Check the pedals on other folding bikes. They'll tell you how much the manufacturers care for little things that get the most abuses.
Reactions: Andy88
5,786
You just have the chain to move out of the way as well as undoing the torque arms.
Reactions: Andy88
Andy88
747
135
69
Ayrshire
Is there nationwide service centres in the UK for these crank motors? How much to replace one?
sent via huawei P9
trex
7,703
2,671
AK runs his GSM with a torque simulation controller. The motor costs £215 new but they are easily serviceable by good DIYers. The only special tool you may need is the BB nut remover. It's the same tool used to service the BBS01 and BBS02. You can make it yourself for about £5 or get one from woosh. You don't need any special tool for jobs like greasing or replacing the motor core. Woosh also sell the GSM with internal controller with LCD and accessories, comparable to the Bafang BBS01 kit, for £275.
http://wooshbikes.co.uk/?cdkit#gsmkit
Reactions: Andy88
Andy88
747
135
69
Ayrshire
Would I be better of with the crank motor than the Big Bear?
sent via huawei P9
poptop
75
9
72
mind in a tiz, but to get maximum battery/bike for best bucks in a folder I seem to be heading for the Gale with 13ah battery. This seems my best bet. As instructed dive in and give it a try was some advice. With good feedback on Woosh, seems a no brainer, unless someone throws something else into the pot [ maybe technical stuff, the novice is not aware of].
but only 12 months guarantee....
Andy88
747
135
69
Ayrshire
For what its worth im also steering towards a woosh, I'm around your age albeit a different body size so wont be the same model.
When you weigh everything up the woosh bikes seem less padded with marketing gimmicks and middleman costs resulting in good value for money.
sent via huawei P9
poptop
75
9
72
interesting comment Andy, it was that or wisper 806 but that is over £400.00 more, and I don't really know what Im getting for that extra money.
you going for big bear by any chance?
Reactions: Andy88
Andy88
747
135
69
Ayrshire
Im looking at the big bear LT, or a Crank Drive as I weigh 120km
Trex made a good point on battery and motor so i would look at those replacement costs, any other component could be cheaply replaced,. £400 is a substantial amount of money, I am as the same thought as you, what am I getting for the extra?
sent via huawei P9
