Which ebike to choose?!
3,344
Don't have an old bike and it would mean spending money on buying one and upgrading the parts and I'd then once I'd bought the kit I'd still have plenty left on the voucher that I couldn't spend lol
It's a shame nobody seems to be selling and accepting CTW vouchers for professionally pre-converted bikes (AFAIK), for those wise people who value long term repairability at home as well as performance, reliability etc.
17,149
we can and do often accept CTW vouchers to convert your bike with guarantee it but usually the customer has already got a decent donor bike.
3,344
Why don't you sell them a decent donor bike aswell? You could charge extra for upgrading various components to suit their max budget.
17,149
It would be about £120 cheaper to build the whole ebike compared to bike + kit + fitting labour. To make your scheme worthwhile, I would need to buy bankrupt stock bikes, I would then run out of space to keep them. The best use of space is crank drive kits then hub kits then bikes.
3,344
Looking at the Woosh storefront, I'm wondering if you can get planning permission for a roof raise and an extra floor. Someone I know did that to rented premises, plus a basement extension, and the landlord immediately increased the rent to suit the increased floorspace. The resulting row got quite awkward, because both the tenant and landord are my customers.
https://goo.gl/maps/Cg3uk3SsLnQVvkuK7
8,734
Yep definitely a factor in my thinking. The thing that puts me off EAPC is warranties are short and once they run out you have a very expensive peice of tech that isn't cheap or easy to fix especially when batteries/motors are 'built in'. Conversions are less of issue in this regard and if I decide down the road that I no longer need/want assist then I still have a good bike once I remove the kit. I can really make a strong argument either way though hence the indecision.
If you buy mid drive then yes, out if warranty they could be expensive trellis's as they are closed systems however a generic hub bike is a different thing and far more reliable over the long term.
Az.
2,170
983
Plymouth
Reactions: mtjnr
thelarkbox
1,499
468
oxon
Although i ride on a kit conversion (i had a bike) I would just buy a ebike and be done, All kit installs have issues some minor like wrong colour zip ties others less so. why invite a headache..
Also a great bike costing 1000's may not necessarily make an even passable e-bike,
Someone recently described a monster ebike build based on a top notch mountain bike fitted with a top notch mid motor 1000w iirc and 2 months after finishing it he had sold it and bought off the shelf..
i would aim at hub motor bikes with rear rack mounted batteries myself, then if a problem develops after warranties have expired its the motor, or the battery or an element of the control system that needs a fix or replacing.. all do-able imho
And if you follow honest positive reviews you should get a lot of ebike for your budget
17,149
the OP is in a bit of a sub optimal situation because he already has his voucher. The retailer has to pay commission on the voucher. Different scheme providers charge different commission rate. The cheapest commission is Green Commute Initiative. Some scheme providers impose also additional conditions on the retailers such as what they can supply and whether the retailer can give to the customer any cashback etc. In short, his £1500 voucher can only be used optimally to buy from the scheme providers own stores. Outside the providers own stores. his choice of retailers is restricted to those approved by his scheme provider. If you want to buy on CTW for example at Woosh, please email support@wooshbikes.co.uk before applying for the voucher.
17,149
The ones currently on my list of potentials if I go the kit route are boardman HYB 8.6, Specialized Sirrus x 2.0 could maybe push to a 3.0 and a cannondale quick 4.
Out of the 3, the Cannondale Quick 4 has best specifications, then the Boardman HYB 8.6.
Your choice of bike limits the range of kits to lightweight kits like the XF08C rear hub kit or TSDZ2B crank drive kit.
https://wooshbikes.co.uk/?hubkits#xf08ckit
Reactions: mtjnr
thelarkbox
1,499
468
oxon
Happy to be corrected, I know nothing of the scheme its limitations and restrictions.
I shall get my proverbial coat.. .
mtjnr
32
It seemed to me that the sirrus and the cannondale had very similar specs (both tektro disc, microshift etc) but I liked the fact the sirrus had the slightly chunkier tyres. Wonder if the cannondale would take 42s?
17,149
from the photos, possibly 700 x 42c without the mudguards but may be not with the mudguards. Bike comes with 700 x 35c tyres.
mtjnr
32
Yeah that was my thinking. Mudguards will be a must.
How do think the
The other bike on my list was the Marin DSX.
Not sure how the specs compare to the cannindale and the specialized. They seem good but I don't know whether microshift is any good etc?
3,950
1,142
3,746
Isn't the voucher just a loan? Don't they take the money back from your salary? If that's the case, you might want to think again about your logic that's telling you the more you spend the more you save.
mtjnr
32
I didn't say that at all. I'm saying I already have the voucher. The voucher is for a set amount. I can't change that now. Once you have the voucher for the set amount you can't change it. I didn't make the decision to go with a new donor bike because I thought it would save me money. I just couldn't find any 2nd hand ones that were right for me at the time. So I applied for a voucher that would cover either a new ebike or a new donor and kit. And that's where I'm at now. Deciding which to go with.
mtjnr
32
So its decent but flawed as expected for the price range.
Thanks for sharing. So they sound fine for the price point. What I don't know is how they and the other parts used compare with those used in the sirrus x 3.0. Its just total lack of knowledge and experience on my part but makes it difficult to what the better bike is. Maybe there isn't enough difference to matter?
17,149
There isn't much difference between those 3 to worry about. When riding on electric, you would never need the small chainring. Single chainring leaves you with more space on the handlebars.
Reactions: Peter.Bridge
Peter.Bridge
1,583
727
What makes a good donor bike ? Not sure it is quite the same criteria as choosing an analog bike ? More emphasis on how rugged the components are rather than lightness, particularly the chain / gears in a mid drive that is going to have to cope with several times the power a human could generate ? Hydraulic brakes. Also gears, don't really use the lower gears on an electric bike
Reactions: mtjnr
