Which ebike to choose?!
mtjnr
32
I have finally received my cycle2work voucher and after months of research I still haven't decided whether to get an ebike or a new non assist bike and an conversion kit.
I have a top budget of £1500. My main use will be a 30 minute commute to work and back 2/3 times per week. Ideally I would also like to use for leisure rides on weekends. I'm not totally unfit, 6ft, 15 stone.
My question is if you were me and had my budget. What would you go for? If ebike, which one would you buy today? If non assist and kit, which ones?
Really keen to see if I've missed any good options in my research and also just to see what everyone else would go for if they had one choice today!
Peter.Bridge
1,237
564
Or cheaper option
Or a lighter weight, road orientated option
Reactions: mtjnr
mtjnr
32
Or cheaper option
Thanks Peter, do you own/use one of these yourself? Would recommend?
peterjd
213
52
[/QUOTE]
peterjd
213
52
Woosh are well respected on this forum, and are also trade members. My personal experience has been of a converted very conventional (old) lightweight touring bike using a much modified (to mainly achieve desired weight distribution) early (Mk 1) Swytch kit with cadence sensing. More recently I bought a Decathlon 500E bike in the January sales (just <£1000 at that time) with torque sensing, disc brakes and front suspension which toured successfully this summer around Norfolk. I love both my bikes - the new one is much better suited for off-road paths. Peter
mtjnr
32
Thank you Peter. Yes I'm aware of woosh and have been in contact with them. They are definitely on my list of options for both ebikes and kits depending on what I ultimately choose.
I'm not sure if my cycle2work voucher will be eligible with decathlon but I will check it out as the 500e looks a good spec for the price and by the looks of it it fits my oreference of range over power as well. I'm happy to pedal but would like to be able to go for long trips without running out of at least minimal assist.
Peter.Bridge
1,237
564
Not owned one, have bought a kit from Woosh, v good customer service. If I could only have 1 ebike that would probably be the one I would choose
8,525
I don't see the point of buying a new push bike then adding a kit as one loses any warranty issue with the bike. For £1500 one might as well buy an EAPC and have the warranty lock stock and barrel.
Reactions: guerney
3,213
With your budget, I'd convert an old bike... but unfortunately not many kit sellers I've ever seen accept CTW vouchers. £1500 would get you a bloody good conversion.
Reactions: mtjnr
16,843
Let's say you split your budget halfway. 50% for the bike and 50% for the kit.
Which pushbike would you buy with £750 budget?
Az.
2,032
900
Plymouth
I vote for bike and a kit. Which one depends on what you need it for and on bikes you like.
mtjnr
32
The ones currently on my list of potentials if I go the kit route are boardman HYB 8.6, Specialized Sirrus x 2.0 could maybe push to a 3.0 and a cannondale quick 4.
mtjnr
32
Don't have an old bike and it would mean spending money on buying one and upgrading the parts and I'd then once I'd bought the kit I'd still have plenty left on the voucher that I couldn't spend lol
Reactions: guerney
mtjnr
32
I don't see the point of buying a new push bike then adding a kit as one loses any warrnty issue with the bike. For £1500 one might as well buy an EAPC and have the warranty lock stock and barrel.
Yep definitely a factor in my thinking. The thing that puts me off EAPC is warranties are short and once they run out you have a very expensive peice of tech that isn't cheap or easy to fix especially when batteries/motors are 'built in'. Conversions are less of issue in this regard and if I decide down the road that I no longer need/want assist then I still have a good bike once I remove the kit. I can really make a strong argument either way though hence the indecision.
3,213
Haven't you just made a strong argument for a conversion? Then the question becomes "Which conversion?"
Reactions: mtjnr
mtjnr
32
Yes bit I think there are pros and cons on both sides tbh. If I go down the conversion route then I struggle with which donor bike is best. Not a huge range of hybrids under £800 with good specs. Which would you choose if you were buying one today?
3,213
If I were in your shoes, I'd be looking on ebay, Gumtree, Cash Converters/Generators, Faceache Marketplace etc. for a good quality used bike appropriate to my height, weight, use, and conversion kit - the value of good quality bikes seem to depreciate quite quickly. You can always upgrade parts.
mtjnr
32
I can't though as those places don't take cycke2work vouchers. And I can't change the value of my voucher now so if I spend say 750 on a conversion kit then I still have 750 on the voucher that has to be spent so I might as well spend it on a new push bike for the conversion. I did look at old bikes a while back before either applied for the voucher and I found it very difficult to find ones in decent condition that had disk brakes in my area.
Az.
2,032
900
Plymouth
Nice bikes you chose, but if I were you I would be looking at bikes around £1k. Depends how much money you want to allocate on kit.
mtjnr
32
So I guess my the purpose of my post is if you think I should go down the conversion route, if you had 75
Which bikes at 1k are better?
