Which Crank Sensor do I buy?
Cammyweir
Jul 28, 2024
So I bought a second hand Carrera Vengeance E Bike the other day however I noticed the Crank sensor was missing/ ripped off. I was just wondering if there was any way of identifying which crank sensor I need to purchase to replace it as I’ve seen there’s a fair few versions. I do however have a partial bit of the cable which has 4 pins.
3,121
You need the 4pin version.
3,121
They're all 4-wire ones. Don't buy any used ones if the outer sleeve insulation has pulled out of the plastic main part. 1 looks sort of OK, 2 is OK, 3 looks like it's been pulled. There should be a cable tie on it that holds it in, which you can see in picture 2,
FrustratedVengeance
Nov 8, 2024
Can you replace the old crank sensor with an upgraded or new type? i can only seem to find old/second hand ones and was therefore thinking of purchasing a newer type sensor if its interchangeable?
3,121
Give them a call to see if they have them yet.
The early ones work with 4 wires, the later ones have 6, so they're not interchangeable.
FrustratedVengeance
Nov 8, 2024
Thank you , i was hoping that maybe i could remove the old and replace with a new type of crank sensor, is or has this been done before that you know off. Again thank you for your help
