which conversion kit should i get?
hey d8veh can you post a link to a good 700c conversion kit and a link to a good battery to go with it,thanks bud.
There's so many kits. I need some criteria to go on. What do you mean by good? They all work!
ebikedude
23
ebikedude
23
No, you want 230v UK plug.. If you didn't specify,send them an email.
You'll have to change the connector at the controller end of the battery lead. They provide it for you. You'd need to show me the connectors on your throttle, PAS and brakes to comment on them. Even if they're the same,you have to check the colour sequence is the same. Sometimes you have to swap the pins over on the throttle or PAS.
hi d8veh im still waiting for the KU65 to come i uploaded some pics of my old controller so maybe you will be able to tell me if i will have to change anything around.thanks
It looks the same, though you should check the colour sequence on the connectors. The earlier ones had the large white connectors for the the brakes (like the throttle one); however, the last KU63s that I received had both. Hopefully the KU65 will be the same.
