Ok I give up
What are the wheel nut sizes on my Suzhou Bafang SWXB electric hub wheel ?
The flat is 10mm, the thread thickness is 11.92mm but a 12mm nut don't fit. I have tried Halfords, another specialist bike shop and a dedicated tool shop. No luck. The tool shop found an imperial (UNF/UNC ?) thread, 7/16th I think, that sort of fitted but was loose. Are these old specific bike threads from the 60/70s or something ?
I have a closed ended (dome) nut and really wanted an open ended nut as now I have fitted a torque bar and a washer on the outside of that, I want to make sure I have enough thread on the nut. Probably just paranoia
The nut on the motor wire side is perfect, open and has a serrated edge to grip, so I wouldn't need the additional washer.
Closed Ended Dome Nut (but what size ?)
Just checked my terminology the one I want is called a flanged nut
Regards
Jerry
Regards
Jerry
