wheel and tyre to big for the frame can i make room by bending the bars ?
angellonewolf
43
bit off topic has any one ever made a good job of making more space in between the rear bars
and how much clearance should you actually have
Show us a photo of the frame in front of the wheel.
5,786
Easier to buy a new wheel and tyre isn't it?
angellonewolf
43
its a 700x23 at the moment but nearly come off the other day as leaves and wet so got a 28c tyre as i think i need more tread but it leaves about a 1mm each side and with a very slight wobble in the wheel it nearly rubs prob would with my weight on it as when you corner you get flex
angellonewolf
43
if i stick to the 23c its fine
am thinking of trying a 25c in it but want to know how much gap i need each side
5,786
OK so it is a road bike frame, personally I wouldn't try bending one of those. I was going to say 25C but you beat me to it. I have 2 mm clearance with my rear tyre, I had it trued by the bike shop because it went out of line after about 100 km.
chris_n
815
475
63
Niedeau, Austria
Is a 5mm wider tyre going to make any difference on wet leaves? In fact is any width of tyre going to make any difference when the lack of friction is between different layers of leaves. A cyclo-cross tyre may give you slightly more chance as your contact points will have higher point loads but I don't think your frame sounds suitable for them.
angellonewolf
43
delta cruiser schwalbe 28 c on the front witch has a lot more bumps on it and can go to the higher pressure but its not got a lot of space to get much more in the back
