What's the answer?
egroover
1,050
635
57
UK
Back in the early 80s I was running bear trap pedals on my BMX. Still got the scars on my shins!
57952
Reactions: AndyBike
16,915
Is that motor with torque sensor a available commercially ? I quite fancied trying to do a lightweight build. If not I guess I could use a Bafang 370 or akm85sx and use your bottom bracket torque sensor kit
The new Tongsheng hub kit arrived last week. I have been using it on my bike.
The kit comprises of a 1.8kg motor, a stem mounted LCD, a controller in standard aluminium casing and two cables: one goes to the LCD and the other to the motor.
stem mounted colour LCD:
Here it is mounted onto a 10kg full suspension bike with a 36V 10AH battery.
First impressions are excellent. Quietly powerful. I went up Pier Hill at 15mph with ease.
Reactions: Peter.Bridge
16,915
Yes. It's the size of a 6 fet controller
16,915
It behaves as expected, so expect 250rpm. I am still getting to know the new kit. There is no manual yet.
Peter.Bridge
1,328
609
So a full suspension torque sensored e-bike with 360Wh battery for 14kg ! Bet you can't buy that anywhere !
