Range
Hi CJB
Range is a tricky one, as Flecc says it so much depends on how you would use the power. On the Wisper you have the standard pedelec mode plus the use of a throttle so you can decide exactly how much power you require for any given circumstance. This wide choice and unlimited access to power does tend to give massive variations in range, depending on how the bike is being ridden. On road tests we have achieved over 120km (70miles) from one charge so it does very much depend on the rider. If you set the Wisper to the low range you would get at least 50 miles out of it probably more, however if you were to use the throttle flat out for the whole journey you may as much as halve that.
I have just finished a survey of some popular bikes which you may find interesting, on the whole it shows that the larger the capacity of the battery the longer the range.
If you look at the figures (all published on the various websites) the range correlates quite nicely with the battery capacities.
This was not a scientific survey and I may have made some errors but most ebike manufacturers are claiming about 1 mile for every 10Wh.
All the best David
Bike Volts Amps Capacity Range (Minimum published)
Wisper 905se Li Po 37V 14A 518Wh 56 miles (90km)
Wisper 705se Li Po 37V 14A 518Wh 56 miles (90km)
Urban mover Li Po 26V 12A 306Wh 28 miles (45km)
Wisper 905eco Li Po 37V 8A 296Wh 29 miles (47km)
PowaCycle Li Ion 26V 10.5A 273Wh 27 miles (43km)
Kalkhoff Li Ion 26V 10A 260Wh 26 miles (42km)
Swiss Flyer Li Ion 24V 10A 240Wh 25 miles (40km)
Giant Twist Li Ion 26V 9A 234Wh 30 miles (48km)
Urban mover Li Ion 26V 9A 234Wh 21 miles (34km)
Wisper 806fe Li Ion 24V 9A 216Wh 24 miles (39km)
Izip Li Ion 24V 9A 216Wh 23 miles (37km)
