warning about ENERPROF.DE / ENERDAN battery&accesories
cyclebuddy
1,660
777
Beds & Norfolk
the chargers came with the bundle with the battery, you can find them here, i have 5 amp and 8 amp versions with 54 volt current and xlr-3 connections https://enerprof.de/en/collections/chargers-lifepo4-15s-54v and im not going to stick my multimeter to to the xl3-r outputs because i dont know what holes are positive and negative and what is the "ground" wire, its enough evidence to me that i tried both chargers to see if there is any difference in the battery max voltage after charging and there is no difference, so i dont believe the chargers are defective.
I've dealt with Enerprof.de and found them nothing less than professional.
With those charger plugs, you can unscrew the plastic collar and the plug comes apart to see which is plus and minus and measure more easily.
Your expectation to "see around 54.75V" is unrealistic given the charger output is capped at 54v, so maximum charge will be somewhat less than 54v.
Enerprof also do higher voltage chargers up to 58v for their 52v packs.
tomtom81
20
-1
You put your probes onto the two outer pins of the charger connector. The middle one isn't connected. It doesn't matter which way round. Set your meter to 200v DC. If you don't know how to do that, show a picture of it.
When you've done that, so the same to the battery - stick your probes into the outer two holes. try with the battery switched on and off.
When you've done that, check the outer two battery output terminals with the battery switched on.
As I told you before, but you don't listen, those three results will send you in the direction to get your battery fixed and working.
i´v told you that many times now, i wont be doing what is outside of normal knowledge what i have, i´v read several places that sticking probes to charging side might be harming the battery if the user dont know what he is doing, and im not going to diy repair my battery or chargers because it serves no purpose, even i would diagnose succesfully what is wrong i couldnt repair or even try repair it with out loosing my warranty, this topic is not about i want to fix my battery, this topic is purely my experience with this suppliers warranty protocols and time what have passed which i dont think is lawfull according EU consumer laws, and this is what i want to people to know when they thinking about buying battery from them.
tomtom81
20
-1
those chargers are not for my battery, glad you had positive experience what did you buy?. 54 volt is good for me also i wouldnt complain if i saw this right after charging, i wont be dissembling anything what is under warranty. do you think four months of waiting warranty repair and having back battery what dont work at all, and try repairing faulty battery on customers time is professional? even its clearly against EU consumer laws?
3,858
It's not outside your knowledge, it's inside no because I just told you how to do it. You need to stay off that AI and listen to what people, who know about this stuff, are telling you. I've been fixing batteries and solving battery problems on this forum for nearly 15 years. I'm not some erk on the internet that's been listening to Chinese whispers.
If you don't want to find out what's wrong, that's up to you, but please don't remain here bleating about it. You'll get the same from any oither forum too.
tomtom81
20
-1
i cant fix it because it will avoid the warranty, and to my knowledge this forum is not about just fixing things, its for general discussion everything releated to ebikes, including batteries and suppliers of them, this is thread what i created for warning other ebikers of this suppliers consumer service, what i think they should be aware that if they get faulty product it might take them 4-6 months to get replacement and in worse scenario they might stop answering for any means of contact, has happened to me several times during this warranty job, reason of iso certifications, sick staff, technician being in holiday etc, i dont care about your battery experience as i told you before this thread is not about fixing my battery. and no i dont get the same from every forum infact most forums i have had is positive feedback, are you moderator of this forum or just user? just thinking, did you just asked me leaving my own thread what i created somehow in your jurisdiction? and no, if i hear some guy advice to diy analyse and fix my battery what supplier have told me not to do or i loose warranty, you really think im going to do it?
3,858
You're nuts. How can measuring the voltage void the warranty? Your bike does it all the time!
I doubt that there's anything wrong with Enerprof nor their customer service. I can imagine that they got fed up with you very quickly, not listening to anything and blaming everybody but yourself. I would be the same. I thought I'd give one last chance of helping you, but you're clearly unhelpable. I don't think you're warning anybody, except to warn suppliers that you're a bad customer. You haven't provided any evidence that there's anything wrong with the battery they sent you - just an opinion from somebody, who knows so little, that he won't even measure the voltage.
tomtom81
20
-1
why should i proof my words? it would mean exposing my personal emails,and i wont do it for you, nor should even ask such things, i wont measure the charger and input of the battery because i dont know which is positive which is negative and what is ground wire, and your accusing me of things let mebelieve i shouldnt take any advice from you and overall it wont help the battery to work, it still going for either replacement or going to send it back for refund, why would enerprof ask to send my battery for repairment if it dont need it? no one has blamed anyone expect me enerdan.de for slow customer service and avoiding obeing EU customer laws, i have the proof if it needed like in court. but i dont see any reason why i should give it to you, you know nothing about the company, you know nothing about me, but you sure do seem to know that i am fault of everything, what comes to the battery measuring, all i have word of some random guy from forum telling me to do things what iv read might harm the battery and for what? so you can make your analysis from my battery? how this helps me to get working battery? it´s not, your turning this conversation to your own topic how i am not to be trusted, please leave my topic, your not welcome, i dont need your advice, i dont care what you think.
  • Dislike
Ghost1951
2,193
980
Ha ha ha ha ha -----
Biggest laugh of the day.
Seek help at once. The ebike battery is the least of your problems.
It is important to prioritise which problems are the most serious.
tomtom81
20
-1
and why is that is there any logical reason for this comment or are you just trolling?
and i am seeking help, though probably not kind of you had in mind, but forums admins to kick you trolls out of the forum or at least of this topic.
6,710
try the guy in my sig he does custom batts ,jimmy dead now :(
tomtom81
20
-1
i would like to change the supplier but untill i get refund or new battery my funds are tied to this faulty battery and the warranty procedure, i got email from them that they will get answer in monday from technician about the battery, though dont know when they going to reply for me about it.
6,710
well he might be able to give a bit more advise but dont touch it as then they wont have it back and posting these things are a pita
Reactions: tomtom81
tomtom81
20
-1
that what i thought, i dont want risk the warranty. maybe if the company will ghost me again and i get insurance paying it for me, then i will ask more help for fixing it.
chris_n
801
471
63
Niedeau, Austria
How did you in this post Brexit world manage to buy a battery, ship it back to Germany for repair (as a suspected faulty battery!) and have it shipped back to UK without paying import and export taxes at every stage as well as shipping dangerous goods?
tomtom81
20
-1
because i live in finland and due EU consumer laws, the supplier is resbonsible of these payments anyway.
6,710
tomtom81
20
-1
cannot use just any repair shop saddly, because the enerprof.de is who has to pay it, and they probably want to use their own shop.
6,710
yeah i know but watch some of his vids bosch on the black list :eek:
Reactions: tomtom81
