voodoo zobop conversion bbs02
dbar
66
MY motor is the 36v 25 amp from Em3ev. Which battery have you got to fit in the triangle?
peter.c
1,613
493
thurrock essex
Hi dbar the company has gone I tried to order another no luck
its a beast but heavy just cannot run it flat what chain ring did you use
dbar
66
I'm using a 42 tooth bling ring that I bought with the motor plus I'm using a left hand throttle to keep the right side of the handlebar just for the gears.
peter.c
1,613
493
thurrock essex
IMG_20180814_160031.jpg IMG_20180814_162155.jpg IMG_20180814_163805.jpg IMG_20180814_164719.jpg On a tea break its gonna need a bling ring the actual motor fit went ok:)
only had to grind one bit, the stainless bracket is a time saver rivnuts done:)
the pedal clears the swing arm :)
needs a new chain and a bling ring the triangle almost fits
:eek:
17,432
it's a really neat fabricated piece.
Did you design it?
peter.c
1,613
493
thurrock essex
No cannot claim the bracket its made by California e bikes ,it makes for an easy fit and over- comes bottom bracket problems now both nuts fit easy , just given up for the night .o_O
The triangle battery is fighting back when I measured roughly it was a tight fit
now its a rethink :mad::confused:
peter.c
1,613
493
thurrock essex
got bored waiting for the parts to arrive so went out to the garage and found this:eek: it is getting 29erd and the 350watt and the tri angle
MUST HAVE TO MUCH FREE TIME :rolleyes::DIMG_20180815_194044.jpg IMG_20180815_215920.jpg IMG_20180815_194032.jpg
peter.c
1,613
493
thurrock essex
UPDATE
The 36 tooth lekkie makes chain line worse :(:oops:o_O
now ordered the 42 and now havet to wait again has more dish and a chain guide
The alfine does not have this problem but trying to keep the 10speed
After a long fight the triangle does not work its such a tight fit it will not allow full sus travel:mad::confused:[ so it will end up on the Carrera all the spare bits in the garage]
one step forward two back :confused::rolleyes:
wheeliepete
2,047
757
Devon
You should be ok with 42 tooth lekkie, anything under that has no dish because of the gear housing as you found. Didn't realise you were trying to correct chainline, otherwise I would have shouted earlier. We all live and learn.(most of the time, anyway);) What you gonna do about a battery?
peter.c
1,613
493
thurrock essex
The battery will come off the road bike as a temporary measure [21ah from insat with ga cells ] and if I like to ride fs we will have to see
