Thanks, it's good to get all the pros and cons of each solution.
I've had the T24 in the test tank for just over two hours now, running at speed one, which uses around 10 amps at 12 volts.
This shows up on the source wattmeter as 2.76 amps at the bike battery's 36 volts.
It's the speed I use most on the kayak, about 4mph, which equates to a fast "cruising" paddle.
After two hours, the wattmeter is showing 5.79 a/h used so far, and the pack voltage has dropped from 40.87v on starting, to 38.3v now.
If it stays linear, it looks as though I should get about three and a half hours at that speed, about 16 miles. I'd be happy with that from each 36v pack.
The whole battery box weighs 6.5kg with one 36v battery, and 10.5 kg with both. So I'm getting the equivalent of about 60 a/h at twelve volts, whereas my lead-acid leisure battery was 17 kg and had an advertised capacity of 85 amps, (though I guess not all of that would be usable per charge/discharge cycle).
