Pedrinho's recent thread on rewiring a battery pack got me thinking again about one of my pet ambitions.
To be able to use my 36v and 48v lithium ion bike batteries to power my 12v kayak outboard motor.
Rather than hijack his thread even further, I thought I'd better start this new one, (oops, too late )
He thought he could maybe use a drop down transformer, but was concerned about efficiency losses.
That got me thinking again, so an ebay search revealed this: http://www.ebay.co.uk/itm/DROK-Waterproof-DC-DC-Buck-Converter-48V-to-12V-25A-Step-down-Volt-Regulator-C-/331934500980?hash=item4d48d68874:g:SHkAAOSwHoFXqlcL
For just under £25, a DC Buck which sounds perfect for my needs, (and from the UK too !)
Technical Parameters:
The module is DC-DC non-isolated synchronous buck power converter.
Input voltage: DC 48V (Wide voltage range: DC 30-60V)
Output voltage: DC 12V ±0.25V
Output current: 25A (Recommend below 20A for a long term operating, working load less than 80% is conductive to heat dissipation and life of the module.)
Output power: 300W
Conversion rate: 96%
Over-current protection: 35A
Over-temperature: 150?
Dimension: 74×74×32mm
I'm very tempted to get one straight away, but I've made mistakes in the past with this sort of thing.
Does anyone have any thoughts on it ? (good or bad)
96% efficiency sounds pretty good to me, 25 amps is way powerful enough, my motor draws 15 amps max.
30-60v input voltage means I could use it with my 48v 10a and 36v 11a batteries.
Presumably the existing BMS's in the battery packs would work as now, with auto LV cut off, just seeing the Buck as a 36v or 48v motor ?
Output power: 300W
