On / off switch for controller?You've mentioned lots and shown lots. The one thing missing is the on/off switch for the controller.
I'm no expert, but out of the 100 or more controllers that I installed, none of them worked until they were switched on. What you have written indicates that your controller is switched off. If you don't know how to switch it on, that could be the problem.On / off switch for controller?
Sorry your reply has only just come up I hadn’t seen it. I don’t know how to switch it on can you tell me ?I'm no expert, but out of the 100 or more controllers that I installed, none of them worked until they were switched on. What you have written indicates that your controller is switched off. If you don't know how to switch it on, that could be the problem.
Hi again any joy letting me know how you switch the controller on ?I'm no expert, but out of the 100 or more controllers that I installed, none of them worked until they were switched on. What you have written indicates that your controller is switched off. If you don't know how to switch it on, that could be the problem.
They're all different, but none of your photos show any means of switching on, so you should tell us how do you do it?
You know when the controller is switched off because you'll see 0v where there should be 5v, like on the hall sensor red wire. If you have 5v, then it's switched on.
Your wiring looks very hazardous to me, but you don't explain what any of the wires in the photos are. If any of the wires that have battery voltage on them touch any data or sensor wires, you can wipe the programming of the CPU in the controller.
