Somebody recommended these a couple of weeks ago, so I ordered a couple. Whoever it was, thanks.
We just fitted one, which didn't take long. They come with a L- shaped bracket, which we smashed it flat with a big hammer. we then enlarged a hole and bolted it directly to the fork crown. It's very bright and gives a nice even spread of light to enable riding on unlit roads and cycle paths - probably as much light as those single Cree T6 type, but a better spread.
Their main advantage is that they run directly from any battery up to 60v, so no dc/dc converter required. There's a little circuit board stuffed in the back. To make it waterproof, you should seal round the bracket with silicne sealant or similar.
There's no switch, so you have to add your own. I think I paid about £20 for them, but when I just checked, I see that they're only £4.53, which is the bargain of the century. I just ordered another two.
http://www.banggood.com/Motorcycle-Bicycle-Assist-Lamp-LED-Headlights-Modification-Spotlight-p-919876.html
