March 2, 201511 yr Trying to find a nice 'stable' setting for my new bike, the internet wisdom seems to be that heavyweight riders should have loads of pressure in the rear tyre, much less in the front. Makes sense, so... My Marathon Plus are rated at 45 to 115 psi, so I put 50 in the front, and was going for 100 in the rear, got to 80 on my (quite good) track pump, and could scarcely get another push into it. So I stopped on the basis that an exploding rear tyre was not a good idea. Any ideas? Is my pump not up to it, is the gauge dodgy, and I getting even older and weaker than I thought? Something, like the importance of spokes, that I hadn't thought about in decades of bike ownership. A.
March 2, 201511 yr It is very difficult to get above 80 lbs into a largish tyre with most pumps. I never took a Marathon Plus above 80 lbs anyway, they are quite stiff types and easily get uncomfortable when too hard. Being near the lighter end of the spectrum I usually had 55/65 in my MPs. .
March 2, 201511 yr I went to check what the hell PSI was (NZ went metric in '72...) and found that I am running without much pressure - 3.5 BAR front and rear and my Michelin City tyres are very comfortable at that pressure with no sign of sagging under my 78 Kgs. We shall see when I add another 7Kgs of motor and battery... Tony
March 2, 201511 yr We also have metric and BAR measurement but most prefer to stick with the more precise pounds per square inch (lubs per squinch ). conversion is 14.5 lbs/sq" to the BAR
March 2, 201511 yr We also have metric and BAR measurement but most prefer to stick with the more precise pounds per square inch (lerbs per squinch ). conversion is 14.5 lbs/sq" to the BAR Why do you say that PSI is more precise? Surely you can't have been taken in by the old 'it uses a bigger number' argument?
March 2, 201511 yr I meant in the sense of not needing to resort to a decimal point or fraction. In this case the bigger number measure is superior since it spans in whole numbers the whole of the need with tyre pressures. The metric system is an arbitrary one which has many very inconvenient measures, unlike our old imperial one that grew to mans needs over time. .
March 2, 201511 yr Just pump them up until they're hard, which is normally when your arm starts to get tired from pumping. My tyres have never seen a pressure gauge, and I've never had a problem apart ftom that damaged Marathon Plus that kept blowing off the rim at relatively low pressure. Did pressure gauges exist when we were kids? It's a bit like those chain gauges that tell you your chain is knackered after 200 miles. Before we had them, the chain used to last for thousands of miles.
March 2, 201511 yr The walls of Marathon Plus tyres are quite stiff and can lead the inexperienced to believe they are at a good pressure when they’re not if relying on the finger and thumb test. I’m a bit surprised the OPs says that they can take up to 115 psi. Mine have up to 85 psi on the sidewall. 115psi is a good bit more than I used to put in narrow road bike tyres.
March 2, 201511 yr Author John: I did look on my sidewalls, but fading light (fading eyesight) made it difficult, so I took my figures from various sources on the interweb. Your 85 sounds more realistic, as when my track-pump gauge reads 80 the tyre is rock hard. Yes, point taken d8veh about not having gauges till the last few years, and I quite agree that most things are over-measured these days - but the notion that tyres should be softer in the front than the rear struck me as a probably useful idea. A
March 2, 201511 yr ... but the notion that tyres should be softer in the front than the rear struck me as a probably useful idea. That is because the front wheel carries less weight than the rear. Therefore for both tyres to be compressing an equal amount requires the front to be inflated to a lower pressure than the rear. Michael
March 2, 201511 yr That is because the front wheel carries less weight than the rear. Never more true than with the Hillman Imp of yesteryear. After changing it from the intended twin-cylinder engine to a larger four, it was very back heavy and tended to lift the front over bumps. So the standard tyre pressures were 15 lbs front, 30 lbs rear, to keep the front wheels in contact with the ground so it could steer! .
March 2, 201511 yr I meant in the sense of not needing to resort to a decimal point or fraction. In this case the bigger number measure is superior since it spans in whole numbers the whole of the need with tyre pressures. The metric system is an arbitrary one which has many very inconvenient measures, unlike our old imperial one that grew to mans needs over time. . No, the arbitrary system is the imperial one. The metric system relates units to each other in a consistent way. I'm pretty sure the awkward numbers thing is because you have grown accustomed to a certain set of numbers (who could blame you).
March 2, 201511 yr Not so Mike, and you're confusing consistency with arbitrary, the latter having a quite different meaning. I've used metric in engineering from my mid teens onwards and freely use both all the time, depending on which is most suitable at a given moment. I also convert on the fly when necessary, so familiarity isn't a consideration in my preferences. And I repeat, it's the metric system that is arbitrary since it was locked to a randomly chosen arbitrary start measurement that had no logic. As a result it's measures are often inconvenient in day to day life for many. The Imperial system is in no way arbitrary since it developed through experience to match each common requirement on a human scale. .
March 2, 201511 yr Author Having taught English, perhaps I can arbitrate. The imperial system, based largely on body parts (how big's yours?), can be well described as arbitrary. The metric system, which tried to impose a scientific basis for measurement, is certainly more consistent - at least it's based on tens. Me? Like most old people, I use both, as it suits me. A
March 2, 201511 yr Once again I have to disagree, the metric system was based, not on tens, but on an arbitrary factor, the circumference of the earth. Then the construction of a very logical system from that basis makes every measure arbitrary, regardless of it's undoubted consistency. At no time in the creation of the metric system was there any consideration of human needs, and it cannot evolve for that purpose. The imperial system was not tied in such a fixed manner, it evolved and developed over time to suit the human needs. The exact measures and which we used took time to settle and that process continues. We no longer use rods, poles or perches, and the fathom's use is now very restricted, changes showing just why the imperial system is anything but arbitrary. Certainly it's not consistent, logical or mathematically convenient, but those are different matters, humans aren't any of those things either. .
March 2, 201511 yr Once again I have to disagree, the metric system was based, not on tens, but on an arbitrary factor, the circumference of the earth. Then the construction of a very logical system from that basis makes every measure arbitrary, regardless of it's undoubted consistency. At no time in the creation of the metric system was there any consideration of human needs, and it cannot evolve for that purpose. The imperial system was not tied in such a fixed manner, it evolved and developed over time to suit the human needs. The exact measures and which we used took time to settle and that process continues. We no longer use rods, poles or perches, and the fathom's use is now very restricted, changes showing just why the imperial system is anything but arbitrary. Certainly it's not consistent, logical or mathematically convenient, but those are different matters, humans aren't any of those things either. . With all due respect, It's a bit misleading to say that the metric system is based on the circumference of the earth. Only the measurement of distance is. Mass is based on volume (admittedly cubic distance) of water. Energy on heat rise in water, pressure on distance below water. So you could argue it's based on water. Other measurements rely on the acceleration on earth caused by gravity. Distance and time squared. So you could argue it's based on time. Or gravity. Ultimately it's the simplicity with which the units are related that is the brilliant bit.
March 2, 201511 yr Ultimately it's the simplicity with which the units are related that is the brilliant bit. I agree and would never have disagreed with that premise Mike. My contention only had regard to the human scale and needs. The USA have probably made the best choice, metric for science, engineering and finance, and a form of imperial for much of everyday life. .
March 2, 201511 yr I agree and would never have disagreed with that premise Mike. My contention only had regard to the human scale and needs. The USA have probably made the best choice, metric for science, engineering and finance, and a form of imperial for much of everyday life. . Ah, perhaps the imperial system is good for measuring body parts. I spend more time using a measurement system to describe physical quantities of stuff on good old planet earth.
March 2, 201511 yr Not only body parts, but what we use. As I remarked earlier, using BAR for tyre pressures is daft, it's scale not relevant to the need. Likewise but opposite, the gram is far to small in daily use, too often having to be expressed in hundreds and rarely useful singly or in tens. And how many would want to order a litre at a bar? I won't go on, the list of ways in which metric doesn't measure up to the day to day life of most is endless. .
March 2, 201511 yr Not only body parts, but what we use. As I remarked earlier, using BAR for tyre pressures is daft, it's scale not relevant to the need. Likewise but opposite, the gram is far to small in daily use, too often having to be expressed in hundreds and rarely useful singly or in tens. And how many would want to order a litre at a bar? I won't go on, the list of ways in which metric doesn't measure up to the day to day life of most is endless. . ...but the metric system is anything but arbitrary, and that's the problem. A system where the physical measure has been adjusted to 1 unit (pint) in order to make life easier for the inebriated may well be described as arbitrary. And then, imperial spirit measures are far more complex. 1/4 gill? Can anyone honestly say they they have used Gill to measure anything other than spirits in a pub? Even in places where the Gill may be of use it is shunned for the Cup. Likewise the Cup for the Mug, then the Jug, Bucket, Gallon....Don't get me started on the friggin Gallon!
March 3, 201511 yr Likewise but opposite, the gram is far to small in daily use, too often having to be expressed in hundreds and rarely useful singly or in tens. And how many would want to order a litre at a bar? . So you don't do much cooking then? And at the bar you ask for a "demi" which everyone knows is really a quarter of a litre . And a glass of wine is 16cl (hundredths of a litre). Of course in Germany, home of the modern e-bike (notice how I am on topic ), you would be ordering your beer by the litre. Tony
March 3, 201511 yr So you don't do much cooking then? Actually I do and always have done, and it's precisely in cooking where the inconvenience of metric merasures is exposed, ingredients expressed in hundreds of grams rather than the far more convenient ounces and lbs. .
March 3, 201511 yr In my youth I always found grams to be a poor measurement in smaller quantities. Ounces and half ounces and quarters were much better.
March 3, 201511 yr ...but the metric system is anything but arbitrary, and that's the problem. A system where the physical measure has been adjusted to 1 unit (pint) in order to make life easier for the inebriated may well be described as arbitrary. And then, imperial spirit measures are far more complex. 1/4 gill? Can anyone honestly say they they have used Gill to measure anything other than spirits in a pub? Even in places where the Gill may be of use it is shunned for the Cup. Likewise the Cup for the Mug, then the Jug, Bucket, Gallon....Don't get me started on the friggin Gallon! Mike, but you really need to start by accepting the metric system was based on an arbitrary measure as I've already said, that is a historical fact. Then you also once again try to change the terminology, after previously arguing it's consistency, now you bring in adjustment and complexity, none of which I've mentioned or challenged. These in no way change an arbitrary nature, the words are unrelated and have no common meaning. Then you bring in discarded measures like the gill etc, repeating what I've already noted as the imperial systems superiority, it's ability to change according to need. It drops that which is no longer useful or relevant, rather than sticking blindly to a fixed set of measures, regardless of how inconvenient they are. So to get you back on course, please don't argue about the logic, consistency or advantages of metric, I'm aware of them all, acknowledge and appreciate them, which is why I use them as much as anyone else where appropriate. From the beginning I've argued one thing only, that the lack of human scale relative to needs in the the metric system makes it more inconvenient in day to day life, that's all. Here's some proof: First, the metric system was first introduced for universal use in France in 1799, but just 13 years later it's unpopularity forced it's withdrawal and return to their old system. The public in their daily life just didn't think it useful and rebelled. It was eventually reintroduced after pressure from the scientific community in particular, thus demonstrating my argument that it's most useful in specialised fields outside of day to day life. Secondly, the younger half of our population who have only been taught in metric nonetheless rake up imperial and use it for it's convenience. They drink pints and half pints and wouldn't dream of ordering in metric, they buy their milk in pints and never express the wish that it should be in centilitres. They frequently use lbs per square inch in tyre pressures rather than the inconveniently large BAR measure. Even with cars whose manufacturers use Km per Litre etc, the way that younger half have been taught, they prefer to use instead MPG and MPH. They use imperial bike tyre sizes and often express puzzlement about metric measures of those as their questions in here show. I'm satisfied on this evidence that if in weight the lb and ounce hadn't been ruthlessly exterminated by law, they'd use those as well for their greater convenience. Logic and consistency don't come into this, illogical and inconsistent humans do, for that is their nature in daily life, wanting the most convenience rather than the most logical. . Edited March 3, 201511 yr by flecc
March 3, 201511 yr Mike, but you really need to start by accepting the metric system was based on an arbitrary measure as I've already said, that is a historical fact... If you google "arbitrary definition" you get: "Arbitrary: based on random choice or personal whim, rather than any reason or system." Sounds just like the imperial system to me.
