Tsdz2 way too many problems.
Bogmonster666
343
176
Was slightly paranoid about the screws after a few posts - so had a little gander. They came out no problemo. Used a good quality screwdriver and they came straight out. Now, I just need to worry about the CIA following me around everywhere...
Reactions: vidtek and Woosh
16,990
with hindsight, those bolts should have been either anodised or greased to prevent raw steel sticking to aluminium.
3,297
They're one of the biggest buyers of app data. I was considering selling them some - not aiming to sell to them specifically... chances are they'll buy it. :rolleyes:
with hindsight, those bolts should have been greased.
There are no screws on the BBS01B motor casing :cool:, and it's bolts have a layer of paint, but you know that already.
8,599
I think a lot of issues with knackered cross head screws is not using the right screw bit type and size , also best to use a brand new one with no wear.
Reactions: guerney
Sturmey
654
357
68
.......So to keep the controller area waterproof I put silicon sealant to protect it from water where the wires come out of the motor........
Make sure you do not block any drain holes. On mine, the cover is loose at the bottom and there is a slot. I presume this is to let water drain out. I have mine 3 years (2700km) with original firmware/no modifications and have never opened the motor.
51691
3,297
Don't think I'd ever get one of these TSDZ2s anytime, the thought of it breaking down 30 miles from home at any time if I farted in the wrong direction would constantly play on my mind
:D
On top of everything else to worry about, TSDZ2 owners now have screw anxiety.
After the BBS01B submersion, I noticed they have those too - water dripped out for a little while, drying out next to the radiator. Heat expanded air's also got to go somewhere, left it unblocked. Right as rain, works fine.
Reactions: egroover and Woosh
