Hi
My TDSZ2 speed controller has gone a bit wonky. I have been fiddling around with the magnet distance from the sensor, one spoke seems too far away and no speed is recorded, the closer spoke passes very close to the sensor, almost touching it. I originally had it aligned with the round part of the sensor (should have read the manual ...) but now I can't seem to quite get the distance correct. The odd thing is the speedo seems to work as the speed increases but as the bike slows it doesn't reduce. Finally at rest the speed is still saying 18kph for a few seconds before falling back to zero. This is affecting the motor as it works great from start and speeding up but after slowing down doesn't re-start again, well for a while until the speedo sorts itself out. Any ideas? Keep fiddling with the magnet?
