chief eZee Operator
I am not taking on any particular points on this thread. But I would just briefly like to summarise what I know of the situation.
1) There was indeed problem with some of the Li+ Phylion batteries supplied in 2007.
2) Although Phylion have identified and fixed the problem, it is difficult to return to these prismatic batteries that weighs 1.4 kgs more than the current Li+polymer we have been using since.
3) Our current Li+ polymer is the LiMnCo complex. And also with the state of the art BMS with microprocessor that balance the cells all the time instead of only during charging.
4) We have been using our own new generation motor instead of BaFang on the Torq models from 2008.
5) There are various grades of Li+ polymer the supplier could provide each with a built in characteristics to serve a purpose, but very often in life it is give and take. Li+ Battery that could provide high amps output would end up with lower capacity and vice versa. We have to pick one type that is the one with higher capacity, given it is able to give max. output of more than 20 amps is sufficient for e-bike application.
6) When a load is drawn on a battery the voltage drops, larger drop for larger load, and so this becomes a challenge when climbing. If the voltage drops below the protected low voltage level to prevent deep discharge the controller cuts power. Very naturally a large battery works better than a small one.
7) Battery life. The new GM volt has decided on using LG Li+polymer. But note that the battery is working on only 50 % of the capacity, they are made to work between 30% to 80 % of their DOD to extend the battery life. Some years back we tested the LG Li+polymer and we got less than 50 cycles to 60% of DOD, I suppose they have improved as well.
We could not afford to do it this way, we are practically using 99 %
8) I wish to inform all that on all the eZee model it is very easy to add another set of battery in parallel. There are many advantages as noted in the threads earlier. It would definitely extend battery life as the 2 batteries share the work load, with 1/2 the amps drawn and less likely to be fully discharged. We have 3 options to hold the extra battery packs. a) on specially designed battery pannier 2) Rear carrier luggage bag that could also hold ample other things alongside. 3) double decker rear carrier with a flat battery pack ( new ) with lock.
9) We do have LiFePO4 battery available now with the specially designed rear carrier. However it is 37V 8Ah instead of 10Ah. LiFePO4 has lower energy density both gravimetrically and volumetrically. The price is only 30% higher than the Li+polymer, lathough with 20 % lower capacity, but at least double the expected life span. This will go with 2 years warranty for 70 % DOD. This battery has the Cathode material from Phostech. Naturally this could also be used as the 2nd parallel battery set up. This is also an option battery type for the conversion kits that we are marketing.
Best regards
W W Ching
