Tonaro Bighit Remarkable Battery Range
funkylyn
3,172
27
South Shields, Tyne & Wear
Only nominally a Geordie (if at all!) by having lived up here for the last 35 years - marriage to a local girl and all that. No-one I know would ever call me a Geordie (lots of other names mind you). You are right however and I'll be off around the moors this Saturday (62 is no age at all). Actually the ride from Rowley near Consett up the Waskerley Way towards Stanhope is a smashing ride anyway and one I have done quite a few times. Maybe I'll take some pics to post up or even a video!
OK Willin....geordie by marriage then :)
Look forward to seeing pics or video even better
Lynda
mike killay
3,012
1,629
I have got the Enduro model and am still delighted after 3 months or so. I really wanted a sedate road bike (I am 68), but the Enduro had all the answers,
Full 250 watts at any time, pedalling or not.
Twist grip throttle.
Sturdy build.
Crank drive (and the Tonaro is true crank drive, not chain drive like Panasonic)
Things I have changed.
Saddle. I now have a Rido saddle, which is not immediately comfortable but never gets any worse,it has the advantage that you can shift back and forwards on it thus relieving the pressure. Also there is no pressure at all on the crotch.
Tyres, I have Schwalbe City Jets which are slicks and so much quieter, also the bike rolls better on them.
Mudguards. I have fitted full mudguards front and rear. (pm me if you want to know how)
Bag, I have fitted a small sports bag onto the wire carrier.
Handlebars, I have fitted 'North Road' style.
As for the grips, fill them with water and push them on, they seem to stick well when the water dries.
The bike really rides well, goes up anything easily, and has a huge battery range.
If you by from Phil at Powerpedals, you need have no worries, his after sales service is of the best
Artstu
2,420
925
What are they like pedalling above the assist speed? and what sort of speed do they assist to?
mike killay
3,012
1,629
With the magnet on the rear wheel they go up to 15mph, remove the magnet and they might get to 18 mph.
What is the point of pedalling above the assist speed?
Scottyf
1,403
-1
So you can travel faster, lazy bones!
Artstu
2,420
925
I want a bike that puts me on a level footing with club level cyclists, on the hills I'm more or less there, but as soon as the road is flat or downhill they leave me standing, for sure my current bike isn't the best, however I'm enjoying the help climbing and would like help on the flat too.
Willin'
211
Sounds to me as if you would be looking at something like a Cytronex Cannondale or similar (not that I am a good source of information!).
Cytronex Electric Bikes - Cytronex Powered Cannondale Quick CX Hybrid Electric Bicycle
I am sure there will some members who have one of these who could advise.
Here's a cytronex in action (if you have lots of dosh)
Cytronex electric bike races bicycle pro Russell Downing on the Gadget Show - YouTube
mike killay
3,012
1,629
I understand now. There is no drag at all on the Enduro, so I suppose if you were fit enough, you could go faster but I don't think that the gears would be high enough. Bear in mind that it is a heavy bike.
To keep up with club cyclists you would need a light frame, narrow tyres etc.
Scottyf
1,403
-1
There is a valid point with bikes maintaining a steady speed where both rider input and motor work hand in hand to acheive the best effciency and range.
Even geared hub motors will have some drag that makes it harder to owed past the assistance alot of the time. Mist people throttle off when past the assist speed with geared hubs to get a higher speed. But the best average speeds on an ebike are usually achieved by working hand in glove with cyclone with the motor around 12mph.
This is hubs though not crank drive. Glad your range is good and exceeds what most if not all casual ebike users will want.
After all the average commute is roughly 10 to 13 mile each way which you are easily achieving.
mike killay
3,012
1,629
Did some measurements today.
Tonaro Enduro fitted with Schwalbe 26x1.95 City Jets (Slick)
On the flat, top gear, throttle only, slight wind=17.9 mph. (speed restrictor magnet removed)
Ditto, full throttle and pedalling 18.1mph. I am not very fit, arthritic etc.
The wheel outer circumference is 25.9
Front chain ring is 42 teeth, rear is 11 to 32 teeth.
This, if my maths are correct gives a bottom gear of 34 gear inches,and a top gear of 98.9 gear inches.
There are two motor controls, throttle only and pedelec. The throttle gives any where between zero and full power irrespective of the pedelec selector, it overides the pedelec if twisted when pedellecing (How's that for a new word?)
The pedelec is a simple, easily and cheaply repaired plastic disc of magnets on the left hand side of the cranks which passes a sensor on the frame. On the handlebar, there is a three position switch. As far as I can tell, the assistance is either voltage or amperage limited in the two lower settings. Even on low assist, there is slight assistance at 15 mph.
Speeds were measured using a Tesco's wired speedometer. Testing against the flashing speed sign in my village suggest that they are accurate enough.
Fordulike
3,802
1,538
And people complain about speed cameras and electronic speed signs.
I say put one on every street, then I wouldn't have to spend a tenner on a bike computer ;)
steveindenmark
406
Here is a video I made of Jannie riding my Enduro without power. I was riding my Trek racing bike and struggled to catch her when she had passed me. When she turned the power on I was left for dead.
Do bear in mind that Jannie rode her mountain bike the 8 miles to work and back, every day, except for 3, last winter. We had snow drifts and -23 temps. She is no slouch on a bike.
Tonaro Enduro-WITHOUT power - YouTube
Steve
