Looks like content free snake oil to me, and the actual device is not visible in the video clips. Caveat whotsit!
Apparently it says it drives the pedals, but that cannot be 100% true, if you watch the second video.Looks like content free snake oil to me, and the actual device is not visible in the video clips. Caveat whotsit!
The motor in that Youtube vid is a chain-drive. In two shots, you can see that the top run of the chain doesn't go to the top of the chain-wheel.The drive can clearly bee seen in the utube clip below and is a mid drive type unit that sits just under the cross bar above the battery on the down tube. It is said to have PAS capability but very few scant details.
Chris Hobson Tried Out Our TK1 Hybrid Ebike! Check out NOW. - YouTube
As it drives the top chain run, it'll have an idler sprocket as a torque sensor athat will also give the function of wrapping more chain around the drive sprocket.Simon Calder simply packed it in to his rucksack to take it abroad to use on any bike. I can't see it is PAS capable.
In the first vid, at 1:09 and 1:13, the chain goes well above the chainwheel, but at 0:55, it's only just above it, so two completely different systems.I think the utube I linked to is an earlier prototype. In this vid with Calder it appears looks to be a totally different design, it is in the main been blurred out.
Simon Calder Rides Our World Innovation Ebike upgrade kit | TK-ONE Revolution - YouTube
