Hi, you can use a small screwdriver to remove the cables from the plastic block connectors.
On assembly the metal is pushed into the plastic housing and a "barb" keeps it in place.
To dismantle, push the cable into the connector to take pressure off the "barb", use a small screwdriver to depress the "barb", pull the wire to remove the wire (with metal attached) from the plastic housing.
