Something is wrong wih Strava. Your record shows that you dropped 95 ft between 1.1 and 1.6 miles. Thats 95÷2640 = 3.6%. Strava says about 20%!
Ohh I didn't know this, I will make sure I keep it set unpowered thenI thought on starva you were supposed to change the activity type to e-bike so you don't pee off the Lycra brigade. I must admit I've not quite got round to doing this yet on one of my rides last week where I've got the KOM for a dirt track section of my commute.
Hi Eddie, mines only used for commuting it's a shame I knowMore to the point, get it muddy and post up the photos. The more e-mtb off rod users the better. Enjoy the bike.
Thanks for the pdf..Heres the doc for the oxydrive kit as it has more info on the display than the oxygen mtb manual. John at oxygen printed me a one page cheat sheet for the display and settings but I dont have it at work.
Phil I think you managed to change the setting for what type of speed sensor you had, probably number of poles on hall sensor has, which why your speed was wrong.
On another note I've not got bike to check but do the oxygen bikes have a frame serial number any where. I'm looking into getting bike register tagging kit but can get to the point where you purchase it as it wants to know frame numbers.
It's a steep climb. I give you that, but 50%, no. If you look at the steepest part of the first one between 0.7 miles and 1.8 miles, the rise is 1060 ft. 1060 divided by 5808 ft is about 20%. That's quite a long way from 50%Dave, there is nothing wrong with the states of the rides. Taking the section from Lauterbrunnen to Wegnen, it zig zags it's way up beside the near verticle cliffe face, and all cycle guides state that it is not a recommended climb route, and also state that extreme caution is to be taken when descending. I rode up it last year on the pedal bike, had to stop every 50 metres or so, leant on side railings to re-start and puked up.
The ride is 50% in places, and no the Bosch system didn't struggle. I used tour and sport mode, but didn't dare to stop. I guess that not being here, it's easy for you to say that it isn't steep and that I'd know about it if it was.
Skip to roughly the four minute mark of the second video that follows on from below. The nine mile route, was this in reverse.
If I could be bothered to be competitive like you guys and sign up for strava, when my new bike arrives I could show you the benefit of a quality crank drive with a heavy and unfit rider!Leaving aside the always disputable figures, Eddie is showing the benefit of a quality crank drive bike and a light and fit rider.
It is a very powerful combination.
Think I might have to get a new cam hahaAnal ebiker here. ditto -808 #16v3 keychain cam mounted on helmet
Hi did you find your serial number I can't find any numbers which look like a frame serial number any where down near cranks/bottom bracket. In fact cant see any numbers anywhere apart from on main down tube but nothing which looks like a serial number just iso and motor power markings.Thanks for the pdf..
Cheers, yeah probably something silly like that I changed by mistake.
When I spoke to John at Oxygen earlier (sending me the missing kickstand..) he confirmed the S/N is under the cranks/bottom bracket area I think he meant..? I've not looked for mine yet but will do to register the warranty.
