The new best headlight
  • Start date
6,690
i need 20m plus or i just cant see with no street lighting going fast.
Reactions: LeighPing
Yamdude
842
639
Somerset
If you ride like lightning, one day you'll crash like thunder.
But i think you've already had some of that.
5,786
I regularly ride at 30 mph (translating from 50 km/h because I've forgotten mph) in the pitch black of night (trees, no moon) with my b+m on high beam. Wunderbar is a word that springs to mind...
Brightness certainly doesn't mean best, and spread of beam is more important than spot. Cost also doesn't mean best.
This one has an excellent beam. It's not a spotlight. As I said. it lights up everything you need to see.
It comes with two different sized rubber bands, just like all the others. If you use the correct one, it will not move on the handlebars, whatever size handlebars you have.
You can buy spare rubber bands on ebay:
http://www.ebay.co.uk/itm/6-x-Mini-Rubber-Band-PVC-Ring-For-Bicycle-MTB-Road-Headlamp-Light-Torch-/261896194252?hash=item3cfa3ac8cc:g:8kMAAOSw0vBUd2v-
6,690
what 18650 cells would be best for a light from bga/insat just there like 5 quid each and dont want to get the wrong ones.
6,690
they dont sell those lol but know what you mean as there shite get hot and not last to long.
sony ones look good but 28 quid for 4 :(
6,690
danielrlee
1,396
725
Westbury, Wiltshire
torquetech.co.uk
http://www.ebay.co.uk/itm/2x-GENUINE-Sony-VTC5-2600mAh-18650-30A-60A-Battery-/322213438955?hash=item4b056ae5eb:g:MhgAAOSwARZXn6hU
so if i got 4 of those would the charger i have be ok to use with them.
8.4v 1a that came with my cree light.
I stopped dicking about with secondary battery packs a couple of years ago and now run all my accessories from my main pack. I'd advise the same if you are able to do so.
I dont know anything about that seller, so cannot comment on those cells. Assuming they are authentic, they'll be good for powering a light.
If you are putting together your own 2S2P pack from 18650 cells, you should use a 2S BMS as with any other pack. With a BMS, you'll be able to use your existing 8.4V charger as a "set and forget" solution. Without a BMS, you run the risk of cell imbalance and even fire in certain scenarios.
6,690
danielrlee
1,396
725
Westbury, Wiltshire
torquetech.co.uk
its says to charge it when the light flashes so i guess no bms built in to it.
the cells are unprotected so cant let them drop below 2.5v but insat said to use these.
Panasonic NCR18650B 3400mAh
and a charger like this
http://www.ebay.co.uk/itm/322232541505?_trksid=p2060353.m1431.l2649&ssPageName=STRK:MEBIDX:IT
not sure how i could wire a bms in the the above box tho?
I might have misunderstood what you are trying to do. Can you post a link to the light you are talking about?
6,690
so what is the difference to a cell that is protected and one that is not?
6,690
see pic its not the same tho cant i just use this?
IR772
931
1,044
Leominster
If you flatten a Lithium battery to near 0 v it will not recharge using the normal sensing charger, also internal resistance will charge cells differently, without balance a pack of batteries will only operate at the level or the poorest operating cell.
Lithium are very high capacity but not easy to use or abuse like Ni Cd type batteries.
That is not a BMS in your photo it is probably just a low voltage cut out as a BMS connects to each battery for parallel charging and then serial in use.
