Bike all done apart from some water proofing on the battery bag, although the bag is a motorcycle tank bag and is is prob near enough water proof anyway, i ran the cables out of it in black then down the centre stem into the controler via an xt90 connector, was quite pleased that the xt90 would just about take a white 18650 shrinkwrap around it so after i soldered it all up i was able to use up some leftover white 18650 shrink wraps to colour it with the frame, then had the bike upside down and glue gunned everything that looked like a water risk and have obsessivly shrink wrapped everything else, if you are wondering why i haven't tightened the cable ties where the power cables run, this was deliberate, although it would have looked neater with them taught as they are i can remove the battery from the bike without needing to cut them off each time.
every-time i take her to work i put a tick next to £10 on my fridge chart very satisfying indeed!!
Because i went cheap on the 18650s and despite trying to tally each set up i still cant quite get to 56.4 fully charged, iv defo lost some efficiency somewhere but hey, the damn thing is performing great, probobly can afford to only hit 53.9volts if ya rocking 143cells and What i have noticed is how puncy it remainsafter a mike or two, the bottle battery eases up after a mile or so, this one really has legs, going to take both batteries and do a sensible 20mph distance test see if its viable to take to some of my further places of work, start ticking 20s on the fridge
Down sides.. Obvious weight and size of the rear mounted suitcase, although tbf it looks bigger in the pictures! Also continious pluging in and upplugging of the original battery is a worry, it has a cheap looking 2pin male/female setup and looks like it wont last... If i could of got the build up to 54.6 id of happliy left them both plugged in and only seperated to charge.. Oh and i didnt even need to buy a seperate charger just spliced my old one, see pics to follow
